Wiring a Mallory 685 to a Zex dry kit
I monted my 685 box and my 10 lb mottle in the spare tire compartment. I jut made a wire harness that pluged into the box and then ran it under the carpet along the door trim and thwn out the fire wall behind the pcm.
all my relays are mounted on a bracket I made that is bolted to the rad support by the battery so they are easy to get to. All the wires to the solenoinds are hidden inside my stb.
will post pics later.
Just wondering on terminal 85 of the diagram the purple wire from the 685 box plugs in to it, It is supposed to see ground to activate. Well I dont see how that is going to work since there is no where to ground the relay?
