FAST96Z
08-01-2007, 09:39 PM
going to the the track just wondering what some guys have seen what the best psi in 315/35/17 nitto would be to run at the track thanks guys
nittosFAST96Z 08-01-2007, 09:39 PM going to the the track just wondering what some guys have seen what the best psi in 315/35/17 nitto would be to run at the track thanks guys Z-RATED94 08-01-2007, 10:12 PM going to the the track just wondering what some guys have seen what the best psi in 315/35/17 nitto would be to run at the track thanks guys I would think a wide tire, wide wheel, like you have, might like a little more air. It's all about finding the right amount of air for a good contact patch. I would start out at 24lbs. hot and work your way down. See what works, and don't forget that the Nittos love a good burn out to heat them up. FAST96Z 08-01-2007, 10:14 PM thanks will do ill let u know what i run Z-RATED94 08-01-2007, 10:59 PM thanks will do ill let u know what i run Sounds good. And I'll let you know what I run after Fri. night. | ||
