'94 Bad A Z28
08-01-2007, 01:37 AM
Can someone send me the software needed for the cable to work with the PC/Laptop? I just purchased one off a local member but he could not find his install CD.
TIA
TIA
AKM cable software?'94 Bad A Z28 08-01-2007, 01:37 AM Can someone send me the software needed for the cable to work with the PC/Laptop? I just purchased one off a local member but he could not find his install CD. TIA shoebox 08-01-2007, 09:23 AM Software to do what? Program? Scan? Datalog? I'm sure a simple search could give you a quick answer. MEAN LT1 08-01-2007, 10:58 AM Can someone send me the software needed for the cable to work with the PC/Laptop? I just purchased one off a local member but he could not find his install CD. TIA There is no software to make the cable work. Are you using TunerCat or LT1 edit? '94 Bad A Z28 08-01-2007, 12:07 PM Maybe software wasn't the best choice of words, I meant that I needed the drivers for the cable. I looked through AMK's website though and he gave a link in case you lost the CD, so I got the drivers. But I tried to load my program last night and I kept getting some weird error. Keept saying something about a port? Also somehting about the file not being in the correct format? I am using TunerCat and the file is in *.bin format, I thought that is what TunerCat used? '94 Bad A Z28 08-01-2007, 12:08 PM I don't know if it matters but the cable is the USB type. I am new to this so I have no idea about what to do to try to resolve this problem so I can load my program. Injuneer 08-01-2007, 02:51 PM You might want to e-mail Andrew at AKM to see if he can help. stereomandan 08-01-2007, 07:48 PM You need to find out which port your AKM cable is using, and set your software to use that port. I think it is explained somewhere on AKM's website. Dan rngilliland 08-02-2007, 10:56 AM If you can't open the bin file make sure you have PCM_EE or PCM_EEB selected under the ECM tab. The ECM_42 definition file that comes with Tunercat won't open a LT1 bin file. Most LT1 bin files use PCM_EE. | ||
