Monaro sold in U.K. under vauxhall
Ude-lose
12-01-2002, 10:07 AM
The Monaro was displayed at the Birmingham motor show unchanged at the Vauxhall stand for publics reaction.
HSV has previously sold cars in the U.K. unoficially through importers, but their asking price was huge...here is an article on it -
March 2002
Holden HSV GTS Supercharger
Think standard HSVs are a bit sluggish? Then you might like this. You might also be insane
picture (http://www.autoexpress.co.uk/picture_library/dir_4/car_portal_pic_2412.jpg)
The first time you exit a tight corner with a hint of opposite lock and keep this 500bhp supercharged HSV nailed deep into three figures lives with you forever. The exponential lunge of acceleration is stunning, the rise of the rev counter needle matching the increased intensity of the torque and power storm. It's the sort of power that demands total concentration and a healthy dose of restraint. But when the opportunity arises to wring out the HSV it's an absorbing, thrilling and slightly scary experience.
Over the last couple of years HSV has made a name for itself in the UK as the creator of cut-price M5 rivals, HSV matches the German icon for sheer performance and its chassis balance can teach the Munich über-saloon a thing or two, the M5's 400bhp starts to look pretty puny when the supercharged GTS flexes its muscles.
Owners will have to put up with 'only' 340bhp for the first 1000 miles as the standard engine is run in. Then the supercharger, which runs at 0.5 bar, and intercooler can be fitted, with awesome results. Power is up to 502bhp at 6050rpm and torque leaps from 350 to 457lb ft ? albeit higher in the rev range (5100rpm versus 4000rpm).
The GTS has had a raft of styling tweaks for 2002 with new bumpers, side skirts, rear spoiler, front grille and headlamps to give it a sharper edged, more aggressive appearance, which is undeniably menacing if not very subtle. The chassis lacks the GTS-R's more sophisticated multi-link rear suspension arrangement and Hydratrak diff (as used in TVRs) but with an effective LSD the big HSV does a good job of putting all that power on the road. The switchable Racelogic traction control previously seen on UK HSVs has been replaced by a simple factory-fitted on/offsystem. Amazingly, in the dry at least, you'll rarely feel it intervene.
Rather than a sudden rush of torque, the supercharger keeps the same linear curve as a normally aspirated unit. There's more of it, sure, but it's predictable and progressive in its delivery so your right foot has a precise input into what the car is doing. The HSV's weight and size mean you can't take too many liberties, but if you're sensible it's possible to make ruthless progress.
Thing is, the GTS's playful nature means that sooner or later you'll stop being sensible and start really enjoying yourself. The extra power means that if you so desired you could drive everywhere with a twist of opposite lock. The V8 has plenty of low-down power so a satisfying slide can be provoked and held without ever unleashing the truly angry horses at the top-end.
Most of the time the LSV-converted GTS drives much like the standard car. Fast, grippy and huge fun. B-roads reveal admirable stiffness and great body control. The massive brakes (343mm cross-drilled discs front, 315mm rear) are tireless and bite with conviction right at the top of the pedal travel whilst the steering is accurate, weighty and surprisingly direct. The six-speed manual gearbox is a bit ponderous ? but what do you expect when it's handling 500+bhp.
It's when you're really committed that the supercharger makes a difference. Find a good road, use all of those revs and the blown GTS is devastatingly rapid. For those who have sacrificed a TVR for a growing family the pumped-up HSV could be the perfect tonic. If you're after big fun with four doors, the supercharged GTS has got everything else licked.
Engine: V8, 5655cc, 16v, supercharged
Max power: 502bhp @ 6050rpm
Max torque: 457lb ft @ 5100rpm
0-60mph: 4.5sec (est)
Top speed: 180mph (est)
Pic 1 (http://www.autoexpress.co.uk/picture_library/dir_4/car_portal_pic_2414.jpg)
Pic 2 (http://www.autoexpress.co.uk/picture_library/dir_4/car_portal_pic_2415.jpg)
Meccadeth
12-01-2002, 01:43 PM
Holy Sh*t that sounds like a bad*ss ride! Look how small the wheels are though :(
bigsteve7
12-01-2002, 05:33 PM
I agree, hook it up with some 17s or even 18's :D and itd be a really tight ride.
formula79
12-01-2002, 06:36 PM
Looks like a Commodore to me...
AnthonyHSV
12-01-2002, 07:33 PM
It is a Commodore, with the HSV Mods
Ude-lose
12-01-2002, 08:28 PM
sorry , my post may be a bit confusing... the first paragraph is in regards to the monaro that will possibly be imported as "vauxhall" next year, and the rest is an article on the HSV 4-door which is already unoficially imported by a U.K. dealer and sold as a HSV GTS-R in the U.K. but at a steep price.
here is the Monaro they showed at the Birmingham motor show, it had no badging, but was on the vauxhall stand.
http://www.btinternet.com/~adidasman/Images/motorshow/monaro.jpg
Chuck!
12-02-2002, 01:19 PM
You ever wonder how Holden remained hidden from the rest of the world for such a long time? Everything they make is sweet.
kizz
12-03-2002, 04:42 PM
the wheels on that first car (the dark colored one) are just the right size and a nice change from GM's usual K-mart hubcap look. they look a little like those 98 or 99 vette wheels which is a good thing. they already look like 17's to me. it's the perspective making 'em look weird. whatever they are they are just right.
the wheels on that orange car look like minivan wheels with a bigger diameter. get rid of those..
