What Snell Rating do I need
Bow94z
07-30-2007, 12:10 PM
Whats the up to date Snell rating I need for simple street car at the track?
Any good places to pick up a "cheap" helmet for someone with minimal use at the track
Z-RATED94
07-30-2007, 01:35 PM
2005. You can usually find a new cheapy for less than a $100. I did.
Stephen 87 IROC
07-30-2007, 10:07 PM
A M rated helmet is all you need. Open or closed face, your choice. Make sure it has a Snell 2005 rating since that's the newest and will last you for at least 10 more years. You don't need the more expensive SA rated helmets.
Check with your local motorcycle shops. An open face M2005 helmet should be under $100.
Bow94z
08-11-2007, 05:57 PM
will this one work?
http://i22.photobucket.com/albums/b345/bow94z/2007_0811Image0084.jpg
Stephen 87 IROC
08-12-2007, 10:25 AM
Unless it has a Snell decal on the inside, NO.
Some tracks may allow a DOT helmet for slower speed cars such as 14 second and slower. Contact your local track to find out
If you're buying a new helmet, it must have one of these decals on the inside of the helmet
http://www.smf.org/headsup/decals2005.jpg
http://www.smf.org/images/decals/msak05bc.jpg
rock1501
04-28-2008, 12:59 PM
sorry for bringing back an old thread but are helmet ratings good for 10 years?
Is my snell 2000 still ok for this year?
The Engineer
04-28-2008, 04:37 PM
The Snell 2000 expires 1/1/2012 according to the NHRA rulebook. Also, check-out this link.
WD
http://www.nhra.com/tech_specs/ETQuickRef.html
CamaroRacing12
04-28-2008, 05:38 PM
u need a SNELL 95 or newer
mdacton
04-28-2008, 05:42 PM
I still have a 2000 too.
Stephen 87 IROC
04-28-2008, 09:03 PM
Snell 95 is obsolete in NHRA and IHRA for 2008. Minimum requirement now is Snell 2000 or K98 (Karting helmet).
If you still have a 2000 rated helmet, it's still good. If you need to go buy a new helmet, look for a 2005 rating.
The Engineer
04-29-2008, 08:45 AM
As pointed out above, the Snell 95 helmet is "already" expired.
WD
