car to slow, got beat by a SS
DonutMachine
07-27-2007, 12:43 PM
I was racing a ss camaro yesterday afterwork, I'm coming up from behind, but he swerves and gets in my way, eventually pulled next to him. Afterwards we talked, he says he was in 3rd gear(M6)(we're on the street), I was to(A4). I think when I hit 4th gear It would have been all over, but he swears he was only in 3rd playin with me. I need to get more air in my motor, she takes too long to turn over and scream.
dbmason
07-27-2007, 01:19 PM
I highly doubt you are going to be an SS with an A4, I've got an 2001 SS (M6) and other SS's cant beat me, so good luck with that. What kind of street were you on? in town? or what? cause I can do 85 in 3rd, so if you were in town, he proly was just playin with ya.
DonutMachine
07-27-2007, 01:27 PM
i've beaten 4 c5 vettes and 2 mustangs and 1 c4 vette. Is the m6 that much faster than a a4
DonutMachine
07-27-2007, 01:28 PM
flat recently pave two lane road, If your familiar with the Bay Area, we raced down Bancroft
DonutMachine
07-27-2007, 01:36 PM
:cry: time for a procharger
dbmason
07-27-2007, 01:39 PM
I beat c4, c5, mustangs, the only thing i loose to is a 6.0 gto or a c6 vette, or any heavily modded car. i've got video of me beating a c5 vette at the track. and i've never lost to an A4
DonutMachine
07-27-2007, 02:01 PM
really cause i beat gto's, chargers, I can't tell the differeance between the c6 and the c5, they look the same to me(i think lights). I have never lost to a stick car from a dead stop in my LT1(93). He took me from a roll, acutally we both turned left and my attempt to pass him failed. Does your exhaust give you guys a definitve advantage, also ls6 intake right? never mind i'll search
dbmason
07-27-2007, 02:14 PM
the gto's with an ls1 i beat, the ones with a ls2 with 400hp, i dont, c6 vettes have alittle over 400hp, the c6 z06 has alittle over 500hp
DonutMachine
07-27-2007, 03:34 PM
I be going so fast I don't have time to look, must have been c5 then, there cheap now same with the gto's
henryz28
07-27-2007, 05:26 PM
I beat the hell out of my friends 2000 ss m6 in my 96 a4.
JakeRobb
07-27-2007, 05:37 PM
LS1 M6 (SS, Z28, TA, all of them) will go to 100mph in 3rd if the gears are stock.
DonutMachine
07-27-2007, 06:07 PM
how bout this ? should i get now or wait
Patriot Ported heads
New in the box. CNC ported with thier upgraded springs. 2.08/160 valves. Flow over 300 at .600 lift. I checked and they will fit an LS1. 243 castings
$850 or best offer...
__________________
JakeRobb
07-28-2007, 09:05 AM
$850 is really cheap for a set of new, ported, assembled LS6 heads. Let the buyer beware.
Is your car completely stock right now? There are a bunch of bolt-on supporting mods you should do before (or when) you install heads. Full exhaust, intake manifold, throttle body, underdrive pulleys, subframe connectors. Depending on your plans for the car, you may also want tires, suspension, a torque converter, and more.
Once you've bought and installed all of the supporting mods, here's what is involved with heads:
You need to check the combustion chamber volume (it's in cubic centimeters, usually around 65-70), and calculate your resulting compression ratio to make sure you know what you're buying. The heads may be completely inappropriate for you.
You need to match the heads with an appropriate cam (up to $500), and you'll want to buy chrome-moly pushrods as well (~$100).
You can probably get away with using your stock lifters.
You'll want new rockers, but the heads might come with them. A really good set of rockers can cost as much as $1000. Sometimes the kits come with pushrods.
If you're doing the labor yourself, plan on it taking at least two full days, unless you're experienced with this sort of thing. If not, count on spending a LOT of money for labor.
Once you've done all that, you'll need to get your car retuned to support the mods. You can get a mail-order tune for $150, or you can get a dyno tune for $500. The mail order tune will be good enough, but the dyno tune will be practically perfect, and as a side bonus, you'll have dyno numbers to brag about. :)
You should know that installing heads and a cam will have a noticeable effect on your fuel economy. Highway will improve a little, and city will go down a lot.
Now, I'm assuming I've scared you off from getting heads. :)
Please tell us -- how fast do you want to go, and how much money are you willing to spend to get there? Is your car a daily driver? Do you want to race at the drag strip? Any interest in autocrossing? Are you willing to do your own installation when you buy parts? If so, what's your skill level, and do you have access to air tools, a lift, or a welder?
dbmason
07-31-2007, 07:40 PM
not true, my 3rd in my SS tops out at alittle over 85, i've got 3.42 gears, and yes they are stock
JakeRobb
08-01-2007, 07:24 AM
Assuming everything in your car is stock:
Rev limiter: 6200 rpm
3rd gear ratio: 1.30:1
Rear end ratio: 3.42:1
Tire size: 275/40ZR17
A 275/40ZR17 tire is 25.661" tall. Multiply by pi to get circumference -- 80.618".
6200 / 1.30 = 4769.231 rpm at the driveshaft
4769 / 3.42 = 1394.512 rpm at the axles
1394.512 * 80.618 = 112422 inches/minute
112422 inches per minute is 106.461 miles per hour. If you shift at 6000, you'll be doing 103 mph.
Either you're shifting into 4th at 5000 rpm, or a previous owner installed 4.10 gears and didn't pass that information on.
teke184
08-01-2007, 09:00 AM
"I think when I hit 4th gear It would have been all over, but he swears he was only in 3rd playin with me."
sounds like you were in your dead spot on the auto.
and as jake said...100+ is very possible in 3rd gear...and quite honestly...if you had raced higher it would have been uglier.
4th gear is a fun gear for an LS1
overdrive in an auto compared to 1:1 in the m6....i don't think "it would have been all over"...unless it was the other guy winning
LSWHO
08-01-2007, 01:54 PM
__________________
Don't you have an LT1? These won't work for your car.
JakeRobb
08-01-2007, 01:56 PM
His sig says he has a '98 Z28. That's an LS1.
LSWHO
08-01-2007, 01:57 PM
holy crap
LSWHO
08-01-2007, 01:58 PM
I went off this post. Never read his sig.
JakeRobb
08-01-2007, 01:59 PM
holy crap
:lol:
DonutMachine
08-01-2007, 04:13 PM
sold my lt1 or lost it R.I.P.. I set my rev limiter to 6500. I put my own rear end on It came out a 6 speed. I think i just hit my dead spot in 3rd gear. FYI, I just picked up a fiberglass SS hood, big differance. I beat a new gto yesterday on the freeway, he was right behind me, but man those sound so bad a$$ compared to my car even though i have a loudmouth. They sound like the have more low end torque and grunt
00Z28SS
08-02-2007, 05:10 PM
Thats an awesome deal for those heads. Almost too good to be true. Like said before though, you should do the supporting mods first.
DonutMachine
08-02-2007, 06:13 PM
this board has taught me a lot, hell if it weren't this forum I might be driving a honda or something. I am really dumb when it comes to heads and valvetrains numbers and stuff. I just want a really fast car, not a quick or sort of fast car
DonutMachine
08-02-2007, 06:14 PM
supporting mods such as, I need headers, torque converter and some subframe connectors
dbmason
08-04-2007, 01:51 PM
thanks for the specs, thats stuff i didn't know. the car is stock as far as i know with the slp options listed in my signature
1LE4ME
08-10-2007, 07:04 PM
You can only do 85 in third? I cross the traps at 100+ in third, maybe I've got different gearing, M6 here also.
JakeRobb
08-10-2007, 09:35 PM
I'll bet you $50 that you have aftermarket 4.10:1 gears. :)
dbmason
08-30-2007, 09:46 AM
I tend not to shift as high as some, i shift between 5,000 and 5,500 or so, unless i'm racing at the strip, but there i never see the end of 3rd, i barely see the end of 2nd
JakeRobb
08-30-2007, 09:48 AM
That'd be an eighth-mile track, wouldn't it? :)
I cross the quarter-mile traps in 4th.
TobyZ28
09-04-2007, 02:49 PM
Get a higher stall, mine's helped all over the RPM band :) Gears may also help remove some of the dead spots. Unfortunatly from a Roll A4's are always at a disadvantage :(
Anyways, Stalls + Gears + Decent tires + Race from a dig = you FTW!
dbmason
09-06-2007, 09:41 AM
Yes that is the 8th, avg. pass about 8.4-8.9, depending on how excited i am, and weather or not my car has the stero system in the back
dbmason
09-06-2007, 09:45 AM
if i had 4.10:1 gears, i'd be doing better than 8.5 in the 8th
JakeRobb
09-06-2007, 10:12 AM
There could be any number of reasons that your drag strip performance isn't up to par. The speed vs. RPM numbers you gave are dead-on for 4.10 gears.
