Permatex Products - How do you choose?
scottso
07-27-2007, 11:47 AM
Browsing through these boards and looking over Permatex's website - I still can't make sense of choosing the "right product for the job".
I have a small leak from what initially appears to be where the oil pan meets the timing cover. I see many have used "ultra black". I saw a post regarding a temporary fix smearing some "gray" over the leaky area (after cleaning it of course) - which I may try.
But how do you guys choose your sealer and gasket maker. Even if you read descriptions and open the "PDF" instruction sheets for the products they list (high temp, high temp red, blue, ultra blue, ultra copper, ultra black, gray, etc. - not to mention gasket "dressings") there is a tremendous amount of crossover listed for adhesion, flexibility, vibration, fluid resistence, etc., etc..
How can every one be "superior" or "unsurpassed"?
sabre81
07-27-2007, 11:59 AM
why not drop the pan and install a new gasket? Black RTV would be sufficient. Although i LOVE Ultra Copper RTV.
mdacton
07-27-2007, 03:33 PM
Use the import grey or The "Right Stuff"
Thats all I use
Kevin97ss
07-29-2007, 03:44 PM
Ultra black is best suited for engine oil, Ultra grey for gear oil (Diff. covers), Flange sealant for two smoothe machined surfaces, Ultra copper for exhaust flange, Right Stuff for trans pans.
scottso
07-29-2007, 08:55 PM
Is that from experience? You sound confident. I certainly can't get that definitive info from the product descriptions. That's where I have a problem.
Kevin97ss
08-01-2007, 12:47 PM
Yes, lots of experience over many years. Also stay away from anything blue or clear, despite their descriptions there not really good for anything.
Yeah, the product descriptions are confusing at best simply because any compound will seal anything for a short amount of time. The correct compound will stay sealed for a really long time.
qboneus
08-13-2007, 01:30 PM
Thats all I use
Ditto or +1 on permatex "Right Stuff" Bar none this is the most versatile, useful gasketing out there that "I" have ever found.
I wouldn't buy anything else.
Tal
afr lt1
08-14-2007, 11:27 AM
Ultra Copper! I have it exactly in the spot by the timing cover and pan.
