Z/28lover 07-26-2007, 05:37 PM Camaro Manual Transmission
From MotorTrend
"Two six-speed transmissions are available: GM's new 6L50 automatic and the Aisin Warner AY6 manual. The auto ...
Probably barely two percent of American CTS customers will opt for the six-speed manual. Even so, Caddy engineers have put considerable time and effort into optimizing it for the car. The second, third, and fourth gear ratios were changed late in the program as a direct result of testing on the Nordschleife, says Rob Kotarak. (Good news for manual Camaro buyers: Your cars will get this gear set, too.) Though there's no difference-according to Cadillac's figures-between the straight-line performance of manual or automatic cars equipped with the top of the range 3.6-liter DI engine, the manual car clearly feels quicker around the 'Ring, punching harder out of corners and with less of a gap between the second and third ratios. In fact, says Sigma products development manager Rick Kewley, the manual is five to eight seconds a lap faster."
Hell Yes
Found it.... http://www.motortrend.com/roadtests/sedans/112_0709_2008_cadillac_cts/suspension_transmission.html
Fourth paragraph down.
Bob Cosby 07-26-2007, 10:36 PM I did a quick search of the AY6, and came up with these ratios....
4.15 2.33 1.53 1.15 1.00 0.79
That's one OD gear. Assuming Camaro's manual is indeed the AY6, and ratios are close to this, I suspect you'll see a rear gear ratio of something under 3.00:1. Also, That's a HUGE drop from 1st to 2nd (even bigger than the 3.35 to 2.00 in the T3650 found in Mach 1s and 02-04 GTs).
Interesting....more than one way to skin a cat.
Z284ever 07-26-2007, 11:07 PM Doubt the Aisin will see duty in anything else other than the V6.
rickjames343 07-26-2007, 11:11 PM That's one OD gear. Assuming Camaro's manual is indeed the AY6, and ratios are close to this, I suspect you'll see a rear gear ratio of something under 3.00:1. Also, That's a HUGE drop from 1st to 2nd (even bigger than the 3.35 to 2.00 in the T3650 found in Mach 1s and 02-04 GTs).
Is that good or bad?
Bob Cosby 07-27-2007, 01:26 PM Eh....could be both. With such a short first gear, it would certianly move smartly from a stop. Downside is the big drop on rpm from the 1/2 shift.
Silverado C-10 07-27-2007, 01:38 PM .79 is a crappy OD ratio unless you have a high geared rear end... Even the archaic 700R4 was .7:1.
Bob Cosby 07-27-2007, 01:44 PM Yes, but note the really short 1st-5th ratios. That will allow a really high rear end gear.
97z28/m6 07-28-2007, 12:51 PM Doubt the Aisin will see duty in anything else other than the V6.true. i bet we get a version of the t-56 in the V8 models.
PacerX 08-08-2007, 09:52 AM Obviously, two things come to mind...
A DI V6 doesn't behave anything like a NA V8 or a supercharged V8, so the ratios are obviously up in the air.
I second the idea that this tranny most likely doesn't have enough nads to take what the big V8's are going to put out, and that a T-56 variant would be a better bet.
Z284ever 08-08-2007, 11:31 AM Obviously, two things come to mind...
Hey, it's PacerX. Long time, no see.
Would seem to be ratios for a small engine in a heavy car, or a small truck. Can't imagine that in a V8 Camaro over here.
LeadSled1 08-15-2007, 01:30 PM Somewhat similar in gearing to the A6 in the new Vettes:
4.027 2.364 1.532 1.152 0.852 0.667
They only come with 2.56 and 2.73 gear ratios. The 2.73 is the performance ratio.
I would rather go with the different internal gears and have a larger rear gear for more strength.
ImportedRoomate 08-15-2007, 04:02 PM I thought the Camaro would be getting something like the TR-6060 in the GT500.
I'd agree with that, but I wonder if having a larger pinion in relation to the ring gear is better for efficiency? Might be worth a tenth MPG? But normally a 4 to 1 first gear ratio is not all that strong in a gear box I'm thinking. Guess we'll wait and see.
93Phoenix 08-17-2007, 05:35 AM Glad to see GM's joined the 21st century with their gear ratios. The ratios in my Buick load the crap out of the engine. But whats up with the insanely steep 1st gear, are they encouraging tire spin? :wtf:
