LTCC setup
camarolt4ss
07-25-2007, 11:36 PM
does anyone with the LT series engines have this done?? is it worth doing vs say delteq?
any imput would be great
as well what it should cost to do
thnx again
Boosted_Z28
07-26-2007, 10:13 PM
Yes, it is a great upgrade, especially if your Opti-spark system is in need of replacement. Costwise, it depends on where you purchase the coils and hardware. I really liked the LTCC system when I was running it on my LT-1 and it had a few capabilities that the Delteq didn't. Be sure to read the information on both their websites so you can make an educated decision.
http://www.bailey-eng.com/
http://www.delteq.com/
joe-96z1le
07-27-2007, 06:04 PM
I have an LTCC setup with the stock style LS coils and Magnecor plug wires. It's not a cheap conversion but mine is working well and the spark is good even with the s/c.
camarolt4ss
07-27-2007, 06:49 PM
what did the conversion cost u?
Boosted_Z28
07-27-2007, 07:46 PM
The interface box and harness is $399. You will need 8 coils GM #12558948 will work. Sometimes you can find the LS-X guys selling them. Check E-Bay, or you can purchase them from here: http://www.gmpartsdirect.com/ for $37.50 each. You will also need a set of universal style ignition wires and accessories for the wires. Additionally, you will need to fabricate or purchase some coil brackets to mount the coils to the car.
joe-96z1le
07-28-2007, 01:30 PM
Boosted Z pretty much nailed the price. I'm using Magnecors 10.5 mm wire custom made so add $100 for that. The coils you should be able to pickup used but I bought mine new. I used the relocation brackets sold by Thunder Racing for LS1 cars and modified it. $60 there. You also need to consider what to do with the opti. I chose to convert my Dynaspark to a Gen III version. You can use the opti but I didn't like the idea of leaving the rotor in there in case it broke up and took out the sensor. So, you can leave as is or pull the rotor out and have a bushing made to replace the rotor.
mrz28 73/97
08-26-2007, 02:53 PM
I looked on Thunder racing and I didn't see the coil brackets like the ones in the pics on Bob Bailey's site, does anyone know where I can get those from or who originally made them?
Bowtie_Z28
08-26-2007, 04:08 PM
http://www.buickgn.com
They carry them, will run you $275 for the brackets and covers.
blackcars
08-27-2007, 06:03 PM
Is this conversion from LTCC or dynaspark give more hp from the go? I'm putting an STS kit on my 383 97SS and a few other things and i'm considering going to one of these systems eventually. Thanx for any input...:bow:
