02BlkBullet
07-25-2007, 11:58 AM
Hey guys,
I bought a replacement opti from a guy on this board and I ran into a problem that I haven't ever see/heard of before. I took the cap off and made my alignment marks. It just so happened that it was at TDC which was also straight up and down on the rotor. I went ahead and took everything off and looked at the alignment pins of each and matched up the replacement's rotor with the old opti's rotor. Well, the problem is that when I do that, the alignment pin grooves are different...way different. They are roughly 100 degrees off from each other. Should I install the new opti using the alignment groove and ignore where the old rotor was on the opti or should I shave the alignment groove down into a pair of teeth to simulate the regular splines and install it like the stock unit?
Thanks for any help you guys can give.
D
D
