LSWHO
07-24-2007, 09:14 PM
Ok, Mods:
LPE CAI
3.42s
MADZ28 tune (mostly for 3.42s but still...)
cutout (which I think KILLS torque, but not sure)
I ran 14.3ish@96.5ish stock.
I'm hoping for 13.7@99? street tires.
1LE4ME
07-24-2007, 09:49 PM
I don't know if you'll hit a 13.9, maybe with a perfect launch. Get a higher stall torque converter and you should be there pretty easy.
Antz97ZNJ
07-25-2007, 07:05 AM
You should hit what your looking for...id say 13.6-7...btw as far as the cutout goes it all depends on where you put it.
BassProCamaro97
07-25-2007, 08:27 AM
You'll be lucky to hit 13.99. I'm not sure how well your track prep is but on street tires, cutting anything near a 2.0 60' will be difficult.
Hopefully you prove me wrong.
~Jim~
BlackHatch
07-25-2007, 12:40 PM
~Jim~
Who the heck can't cut a 2.0 in and automatic A4...? You should easily cut that 60ft number and 13.7 is possible. I have run 13.7's in otherwise stock LT1 A4's.
BassProCamaro97
07-25-2007, 01:02 PM
My bad I didn't see the A4.
~Jim~
LSWHO
07-25-2007, 01:03 PM
~Jim~
if I can cut a 2.0 60' in a fwd low 13 second gtp I dont think a rwd with less power will take that long to get used to.
BassProCamaro97
07-25-2007, 01:10 PM
Well best of luck to ya then. Go out and run it and let us know what it does. I'm intrested to see how much im losing because of my tires.
~Jim~
Antz97ZNJ
07-25-2007, 02:47 PM
That is true, think my worst 60 ever when my old 97 was lightly modded was a 2.1....Every run after that was 2.0's religiously....Like I said I see u having no problems at all hitting 13.7's
lovescamaros25
07-30-2007, 06:26 PM
You might hit a 13.9 but I dont see you hitting a 13.7.
What is the altitude of the track?
LSWHO
07-31-2007, 07:33 PM
1200 altitude. Firebird Raceway.
My car quite easily put my brothers car to shame the other night 2 out of 3 races. He should be 14.0ish. 20-100ish I put 1.5 cars on him and most of that was below 60. The last race was from a 40 roll up to 80ish and I only had a car on him.
Based off of this I think if my car feels up to it the night of the race I should easily hit 13.7s.
IdahoLT1
08-02-2007, 01:21 AM
A car length at those speeds should equal 1/10 of a sec on the ET. So if for sure your brothers car was 14.05ish you coukd take .15 seconds off that, so 13.9 maybe in theory. Id say you could break 14's, but temp, and traction might be the biggest problem. And youre 60ft time is almost the best you can get for street tires. A few have hit 1.8's but they are few and far between.
