Can't get knock to show on Freescan
mrmint69
07-22-2007, 07:22 PM
My Freescan does not show the knock but has the space where it should be at. Does anyone else show the knock other than the knock count that doesn't change live but has a big number that changes from scan to scan? I was wondering about the sensor or the module now working correctly.
LiENUS
07-23-2007, 12:05 PM
Knock retard shows up blank until you get some then a number will appear, for values bellow .5 it wont show up at all (though it will show up in the datalog)
mrmint69
07-23-2007, 07:57 PM
Well that leaves nothing to do but take it for a spin with the laptop. Thanks
mrmint69
07-25-2007, 12:46 AM
10-15 drive and no numbers so maybe there just isn't any.
LiENUS
07-25-2007, 02:16 PM
Go WOT hard through at least 2 gears (the higher the gear the better)
shoebox
07-25-2007, 05:38 PM
Tap on the block with a hammer. That should get you some knock.
mrmint69
07-25-2007, 07:46 PM
The hammer idea is great. Glad someone was thinking since i never was.
mrmint69
07-26-2007, 01:14 AM
Well i tried the hammer trick and went all over the block and really smacked it good with no knock being shown on the Freescan.
shoebox
07-26-2007, 08:13 AM
Perhaps your KS is not picking it up or you have it programmed out of your computer.
mrmint69
07-26-2007, 09:39 PM
Does the knock cause anything to change in relation like rpm's or such. Can you test the sensor? What would the computer do if you had a sensor that was broken and it was unable to detect it? Would it go into some safe mode and retard a lot more to be safe?
shoebox
07-26-2007, 11:02 PM
You would get a trouble code if there was an open circuit to the sensor and you would see the timing constantly retarded because of it. There is a little knock sensor testing info on my Tech Page and I think Injuneer has listed some testing info before.
mrmint69
07-27-2007, 08:54 PM
I have never had a check engine light or code thrown since my EGR valve was replaced 2 years ago. I have had some sensors unplugged while checking things and never got a code or anything. What can i unplug of safely do that will throw a code for sure so i can see if the computer shows it on my scanner?
shoebox
07-27-2007, 11:50 PM
IAT, ECT in the water pump, MAF...
