ZBLKHELLRZR
07-22-2007, 05:35 PM
I'm stumped here. Brand new box and not a PNP setup so I had to wire it up myself. Using coil part # 730-0491. Plugging straight into the coil the car fires up no problem. Hook the HI-6R up using adapter harness 6000-6708 and it doesn't do a thing. New error codes are stored are flashing on the box either. It has pwr while cranking too. I had to use this pdf file to print their instructions but I'm using figure 1 here http://www.cranecams.com/pdf/90006400a.pdf
I also used this pdf file figure since it seems to reflect the LT1 setups figure 5 http://www.cranecams.com/pdf/90006000d.pdf here. I'm freaking stumped and frustrated as I've been dealing w/ this issue since I bought it over a month ago. Any suggestions would be great. Thanks!
