stock gasket vs header gasket
Old Jul 20, 2007 | 01:45 PM
BlackZed28's Avatar
can someone assure me that i'm correct in saying the stock-type exhaust manifold gasket will not work with headers(pacesetter longtubes).
Old Jul 20, 2007 | 03:07 PM
wildweasel's Avatar
They'll work, you just have to snip the ends.
Old Jul 20, 2007 | 03:13 PM
BlackZed28's Avatar
snip the ends and make new holes correct?
parts guys don't know what they're talking about... he was convinced it was exactly the same as a header gasket and would fit, but i was sure it wouldn't fit directly in. all in all... he wouldn't order me a header gasket because " if you can't get that to fit, you won't be able to get the header gasket in"
Old Jul 20, 2007 | 06:26 PM
wildweasel's Avatar
Pretty much. The OEM has a pair of "hooks" on the end, and the header gasket has holes drilled closer to the outer primaries. Other that that all the holes and ports are identical.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
thenewkid
Nov 27, 2014 09:41 AM
