ta4me
07-17-2007, 12:05 PM
So by searching and coming up with the fuel formulas for Injector Sizing and fuel pump sizing I have a few questions and concerns. I took my car to the dyno to do some tuning a couple weeks ago. And I seem to be running out of fuel at anything over 4800rpm. During WOT runs my FP would spike to about 50psi under boost but when I would get up into the higher rpm I could see it drop to about 40psi. No matter what changes I made in my PE table my AFR was always pretty much the same.
So now I think I am running out of fuel. I when through and checked all my fittings, injectors and could not find any leaks. So my fuel pump was a couple years old so I replaced it. (255l/hr). Found the main pump hose was swolen and kinked, I thought cool, it was probably killing my volume and my pressure was droping. NOT! Still the same result but a little bit better. I also changed my fuel filter.
So here I am searching for some anwsers.
My fuel system consist of:
42lb/hr racetronix injectors
255l/hr pump
New fuel filter
Stock FP regulator
I have a FP guage in the car
My car only made 430rwhp running up to 6000rpm pulling about 9lb of boost through a P1SC. AFR would cosisantly drop points above 4800rpm, from 12.2 up to 13.2@6000.
While sitting here doing all these math problems, If I have 42lb/hr injectors, @100% DC they could only use 194.5 litre/hr of fuel @43.5 psi. That would still give me plenty of overhead for the fuel going back to the tank. I just don't see the pump being the problem.
So if I was losing say 110hp being an A4, that would be 540fwhp. 540 x .6 = 324 / 8 = 40.5 lb/hr/cyl
40.5/ .85= 47.65lb/hr injectors
Could my injectors be to small? But what is with the FP drop?
I'm just kind of stuck right now.
255l/hr pump
New fuel filter
Stock FP regulator
