CaliChevyLover
07-16-2007, 01:08 PM
I replaced my window switches today...and now they dont work. at all. there was one broken fuse so i replaced it. nothing happened.. wat should i do? thanx for the help guys
EVERYTHING else in the car works perfectly. (86 IROC)
fredmr39
07-16-2007, 05:42 PM
why did you replace the window switches? obviously look over your work first if it worked before..
CaliChevyLover
07-16-2007, 05:47 PM
welll my switches were starting to crack in half
fredmr39
07-16-2007, 06:30 PM
put the old one back in temporarily -- see if that one still works
CaliChevyLover
07-16-2007, 06:48 PM
ya i did...as soon as i reconected the battery and tried to test them w/ no success. my bro has a fbody so i'll get him to look at it when he gets home tonite
fredmr39
07-16-2007, 06:52 PM
until then....recheck all your fuses -- even the one you just replaced -- is it still good? the fact that it blew means something went wrong (obviously), and if it's blown again (or other fuses still blown), then there's obviously something still wrong..
CaliChevyLover
i dont think its the window motors either..i dont think BOTH of them would go out at the exact same time
CaliChevyLover
07-16-2007, 06:54 PM
thanx for the advice..i'll check em again
CaliChevyLover
07-16-2007, 10:01 PM
ya i found the problem...loose wires. works great now
