mademan6889
07-14-2007, 09:19 PM
Ok to start i have a 383 stroker.all forged,with an lt4 top end and a dual 58mm tpis throttle body.What size fuel injectors would be the best fit for this car?
need injector helpmademan6889 07-14-2007, 09:19 PM Ok to start i have a 383 stroker.all forged,with an lt4 top end and a dual 58mm tpis throttle body.What size fuel injectors would be the best fit for this car? Injuneer 07-15-2007, 11:52 AM Wrong forum.... this topic is routinely covered on the "Fuel and Ignition" forum. Injector size it determined by flywheel HP. A simple guideline - for minimum injector size on a normally aspirated application, multiply your estimated max flywheel HP by 0.07 Example: 500 flywheel HP x 0.07 = 35 #/HR That assumes a BSFC of 0.476 and a max injector DC of 85%. A better, more efficient tune will reduce the BSFC, requiring less injector. A lower duty cycle is always a good, idea, and that would require a larger injector. | ||
