1987IROC350
07-13-2007, 03:37 PM
I had all the stuff in my sig installed a few months ago.
This car will just not run with the TPI F.I. system. So I've decided to remove all F.I. stuff and buy a combo package. I miss not driving this car and it's been a year.
Which would give me the best drive as a daily driver????
If you suggest something else make sure it is for Vortec heads.
http://store.summitracing.com/egnsearch.asp?N=700+4294845683+4294908216+42949018 03+4294840140+115+400065
confused327
07-14-2007, 11:56 PM
I don't think I'd buy a combo, I'd just get a performer rpm and a vacuum secondary holley. Or if you really wanted to you could get(I think) a spreadbore perf. rpm and a Q-jet, it would probably yield better mileage.
Angelis83LT
07-15-2007, 02:08 AM
Whatever you do. if you go with a non computer controlled system, don't forget chances are you will need to get a standard HEI ignition for a non computer controlled car.
jayman350
07-15-2007, 01:39 PM
my thoughts exactly
i started looking through the different carbs that are listed on summit. it more or less comes down to your personal preferences. I like Holley better than Edelbrock for carbs....but i would buy an Edelbrock Performer RPM Air-Gap manifold to start out with just about any carb.
I would say go with either the Holley street avenger series or a 4160 and buy a secondary metering block and quick change spring kit. A straight up 4160 will be fine, but when the secondaries open up there is no way to control the amount of fuel w/o adding a metering block.
mdacton
07-15-2007, 01:45 PM
How much do you want to spend?
There are alot of things you can do...why do you say it will not run with TPI?
onefastgta
07-16-2007, 08:54 AM
Those parts in your sig are not enough to disrupt the 87 maf sensor. You must have had a combination of problems and/or didn't attempt to tune it.
AutoRoc
07-16-2007, 06:40 PM
Cut a hole in the hood is step #1. :D I managed to fit an RPM Air Gap Vortec intake with a Demon 750 carb under my stock hood. It needs a good 2-3" drop base air filter setup but you'll figure all that out. MSD Billet distributor. Spring it for full advance at 2000-2500rpm. If you add up all the advertized HP gains, you're looking at like....9 billion hp.:D jk You could do a 600cfm Vac sec. Holley for a couple hundred bucks or a custom built Holley from Pro-Systems for maybe $600. The $400 extra could easily be worth it when you consider it will be tuned 99% perfectly, from idle/cruise all the way to full throttle, excellent tech support included and he has refferences as far as the eye can see. I did that option. http://www.pro-system.com/
confused327
07-16-2007, 08:33 PM
I fit an RPM Air gap/Holley carb under the stock hood, I didn't have to cut the supports out but did anyway just for some extra insurance. ~1" drop air cleaner.
1987IROC350
07-25-2007, 05:59 PM
I just got back from the shop. The car runs great. It was the valves and distributor had a crack.
So I left the car there to get the gauges and suspension mods on. I'll get a video soon and post it.
Also thanks again to all who suggested stuff. It all worked out.
I have the BW 9 bolt that came with the car still in it trouble free. Will this 360HP engine be to much for it???
If so what should I put in it??
I'm not going to race it. Just going to cruise with it and an occasional speedburst.
onefastgta
07-26-2007, 09:22 AM
Your 9 bolt should be fine. I am running 1.58-59 60 fts on mine with all the stock stuff other than a ring and pinion change.
1987IROC350
07-26-2007, 04:11 PM
So what gears do you have?
I'm still running stock 3.27
irocz28_305
07-29-2007, 12:16 AM
we got a z28 rear end with a 4.10, my brother has an 85 iroc that we've been workin on for 3 months were buildin a 350 for and i think his came stock with 3.42
_____________________
1982 z28
1985 iroc
soon to get
1989 iroc w/engine and tranny for 200 bucks
