1989 Iroc Z 5.7 Automatic
TFERGUS1
07-11-2007, 02:22 PM
I Need Injectors For My Car
Should I Clean Mine That All 8 Are Leaking And Have 200,000 Miles On Or Replace
And If Replace, With What?
mdenz3
07-11-2007, 02:42 PM
What are your future plans for the car? Can you adjust the tune to compensate for larger injectors? How tight is your budget?
xpndbl3
07-11-2007, 02:49 PM
ford 24lb ones are a popular swap
jaykar
07-11-2007, 05:22 PM
I'd get the SVO #30s since the price difference between
24 and 30s isn't that much more.
Would reguire a programming change in the chip but
would have you covered injector wise to some serious
HP in the future if you go that route:D
JMHO;)
Later
TFERGUS1
07-12-2007, 09:24 AM
I Plan On Selling It To Help Fix Up My 68 Camaro
mdenz3
07-12-2007, 01:14 PM
Then I would look around the for sale boards on here and thridgen.org to find a good set of used stock injectors.
TFERGUS1
07-13-2007, 09:20 AM
Thank You
jaykar
07-13-2007, 04:43 PM
By the way, I have a set of injectors that came out that came out of my old 350TPI. #30,480 miles on them. Went
to #30s on new motor.
Later:)
stanghunter211
07-19-2007, 12:33 AM
30# injectors are going to make you run rich, especially on a 200K mile setup. Even 24# injectors are going to make you run rich compared to the stock 22's. Be careful, going bigger isn't always better. You'll need a tune to keep those bigger injectors in check.
Will
jaykar
07-19-2007, 02:16 PM
Agree on the #22s and no chip change on 200K motor
and not modded. Not pushing duty cycle.
Would only go larger if planning to refresh motor and
modding (heads,intake,cam,exhaust,ect.ect.
If planning to buy new injectors, would go larger and save
$$ down the line if was the case. Then would have to chip
for the larger injectors.
Later:)
