5 speed help no reverse continued with video!
David_H
07-09-2007, 02:24 AM
Well I swapped out the trans that wont go into reverse with a 87 W/C t-5 this is the sounds I am getting from it click the video!:mad:
http://img.photobucket.com/albums/v642/madele/th_knocking.jpg (http://smg.photobucket.com/albums/v642/madele/?action=view&current=knocking.flv)
Angelis83LT
07-09-2007, 03:55 AM
Holy crap.. did it make the sound with the previous one too? has to be something moving. so I would check the clutch/flywheel area.
David_H
07-09-2007, 11:02 AM
LOL my words where WTF!!:mad:
I am not sure if it made that noise with the other trans as the motor was un- corked.
I am going to pull it apart tonight and see whats up. I hope I left a bolt loose in the clutch but I think it is in the trans itself:cry:
Duke
07-09-2007, 05:08 PM
My old WC T5 did that, but when that started I ripped it out and did a whole driveline swap so I never did figure out what the problem was. Basically I'm no help.
Angelis83LT
07-09-2007, 08:18 PM
Yea. mine has a fwapping noise to it.. sorta like if you had cardboard fins on a fan and let it hit things.. But I KNOW mine is the clutch/flywheel. His just sounds scary...
David_H
07-09-2007, 11:19 PM
Took the trans out reinstalled the old one with no reverse noise is gone took trans apart found ut shaft needle bearings are shot along with the main drive shaft:mad:
What is a good 5 speed trans I am sick of these problems I havnt even drove this car yet and its been through 2 t-5's:confused:
92LT1RS
07-09-2007, 11:20 PM
buy a decently rebuilt T-5 and you won't have any problems
JAYDUBB
07-10-2007, 06:45 AM
G-Force T5 at the minimum. The TKO600 is probably the best 5 speed that you can stick in the car.
Or you can stick a T56 in it...
jayman350
07-10-2007, 04:19 PM
thats what i would suggest doing
David_H
07-10-2007, 05:24 PM
Can you use same clutch, bellhousing and drive shaft with a t-56??
Angelis83LT
07-10-2007, 06:57 PM
the clutch will be different.. the flywheel may be too... If it is going into a thirdgen there is one heck of an expense (just getting the transmission is just the beginning.. there are quite a few other parts.) Be easier in a 4th, since you could get OEM parts for it. Something to note though is I have heard the T56 is a good trans, but like any other manual it would need to be built if you start throwing down decent numbers to the rears. I have known a few that have killed those too. Stock t-5's are not exactly great. I would either have one rebuilt with better parts, or buy one already built to handle things.
If you get the one rebuilt that you have now. make sure it is a WC trans... if not throw away and find a WC trans to have rebuilt.
