oil psi question
Old Jul 7, 2007 | 12:23 PM
b.lee's Avatar
oil psi question
I went to look at a 98 trans am ls1 auto 96k miles today
It was warm and when idling only had 20 psi oil pressure on the gauge. (stock of course)
It got a 40 psi pretty easily.
I didnt really get on it either.
He said he was running some synthetic oil in it also.
Do those sound like decent readings?
Would thin oil cause this?
Old Jul 7, 2007 | 02:17 PM
b.lee's Avatar
If you get on the throttle a little, it will go over 40 psi.
It has 40 psi normal driving.
Let off the gas completely and it drops to 20 psi.
normal? common problem? thin oil?
oil is not low, and its nice and clean.
Old Jul 7, 2007 | 05:46 PM
Kraest's Avatar
Retired
Sounds good to me.
Old Jul 9, 2007 | 07:36 AM
AL SS590 M6's Avatar
Moderator
Originally Posted by Kraest
Sounds good to me.
Yep sounds normal to me too.
Old Jul 9, 2007 | 08:30 AM
SSpdDmon's Avatar
I run 0w-30 Syntec (the good Euro blend that everyone raves about) and usually idle at or just above 40psi. At WOT, I probably see upwards of 70psi thanks to the ported oil pump that was installed with the H/C setup. Stock pumps should see close to 60psi @ WOT. When the oil really gets warm, you may even see it dip down close to 25~30psi at idle.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Deadbolt24
Jan 19, 2015 01:29 PM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
