sportline springs
OneFreakZ
07-07-2007, 01:06 AM
hey guys im buying some sportline lowering springs from eibach and i have stock springs on there now with 17x11 zr1 wheels will these springs be a clearence problem onece its lowerd does any one have these springs with the same type of size wheels???should i have any problems with these springs???thanks
Injuneer
07-07-2007, 01:03 PM
Which ZR1 wheels.... 36.5mm offset, or 50mm offset?
OneFreakZ
07-07-2007, 07:33 PM
they are 50mm offset..
Blue89Bird
07-07-2007, 10:44 PM
did you bother reading the FAQ? Everything you need to know is there
OneFreakZ
07-08-2007, 01:11 AM
didnt find it???...thanks
INSANEZ
07-17-2007, 05:29 PM
have 50 mm and they hit bad
Injuneer
07-17-2007, 06:19 PM
Did you follow the mod's recommended in the FAQ?
INSANEZ
07-21-2007, 11:23 AM
yes and I had to make further adjustments like making my own bump stops the are screw adjustable and roll the fenders and tuck them which they still rub with the pro kit on hard bumps but is ALOT better. They are not made to fit nicely on a lowered car, either offset. Just go with the pro kit and you will be alot happier, plus the sportlines bounce worse than a honda with Matrix brand coilovers, the pro kit has a great ride when used with adjustable shocks. I have kyb's and set 6 in front and 5 in back.
hope that helps.
steve
Donohue96M6Z28
07-21-2007, 05:52 PM
hope that helps.
steve
what are you talking about? they werent "made" to fit nicely on a lowered car. I've ran many sets of 17x11 wheels. I've also ran 17x11 50mm ZR1s. I've had both prokits and sportlines. Why did you even mess iwth the bump stops. Raise the car FROM THE REAR DIFFERENTIAL. you will have no problems. With sportlines the fenders will need to be rolled and you will likely have to do the BFH mod. When I had a prokit. I didnt need to roll the fenders. but it will vary from car to car...
Sportlines/17x11s = bad ass.
my old car..
http://i13.photobucket.com/albums/a300/Donohue23/4-1.jpg
xxcoolrollinxx
07-24-2007, 06:46 PM
is that car on sportlines ?
looks good
Donohue96M6Z28
07-25-2007, 02:03 AM
yup, sportlines.
thanks by the way... i miss that car :(.
OneFreakZ
08-01-2007, 02:43 AM
sweet that camaro looks like mine the only difference are the wheels..that stance looks bad i like..:cool:
93zder
08-15-2007, 04:53 PM
Do you guys think there would be problems with a 10.5" wheel and Sportlines?
93zder
08-15-2007, 04:56 PM
my old car..
What do you mean by raising the car by the rear differential?
Zack
08-15-2007, 11:16 PM
if you need to jack up the car, do it by the diff. if you use the pinch weld on the side, the rim will get hung up on the bump stop if you dont cut away the part that needs to be removed
