s.reef
07-06-2007, 09:27 PM
I just recently installed a panasonic headunit. Now my gauge cluster will not light up. I replaced the fuse for the gauges and it still does not light up. Any sugestions??
Help!!!s.reef 07-06-2007, 09:27 PM I just recently installed a panasonic headunit. Now my gauge cluster will not light up. I replaced the fuse for the gauges and it still does not light up. Any sugestions?? Rashiki 07-07-2007, 04:53 AM Bad/Dirty headlight switch? I had my gauge cluster, headlights, foglights and tailights go bonkers and it was the switch. While I was in there, I cleaned the potentiometer that dimmed the interior lights and it works much better now! s.reef 07-07-2007, 11:37 PM Not to sound dumb, but what do you mean by headlight switch?? Also now the gauge totally does not work nor do the interior lights nor do any other lights besides the headlights...HELP!! Rashiki 07-09-2007, 02:47 AM The switch that you turn to turn on the headlights, on the dash to the left of the steering wheel. It's also got a little dimmer on it. Try cleaning the dimmer first and see what happens. Are you sure your taillights work too? Mine screwed everything up. s.reef 07-10-2007, 01:28 AM hmm...well the guages now work after replacing all the fuses, go figure. The taillights still dont light up nor do the guages, I think that i may be grounding out somewhere when i installed the radio. | ||
