Fuel line(s) help!
BLDun
07-05-2007, 06:15 PM
I am changing my fuel lines to braided and when I fed the existing lines back through the wheel well the return line began leaking gas so I put the end in an old bottle I had and figured it would just drain the filter amount or something. I can't get it to quit running. I have half filled a one gallon jug and then I lifted it up in the air and tied it off until I can figure out what to do. How much gas should come out???? I can't unhook it underneath until it quits flowing.
Thanks for the help!!!!
mdacton
07-05-2007, 06:30 PM
how much gas is in the tank?
it will stop unless its siphoning out.
BLDun
07-05-2007, 06:41 PM
Not sure. I have the battery and everything unhooked but if I remember correctly should be about 1/2 tank. If it's siphoning any way to get it to quit without draining the tank???
mdacton
07-05-2007, 06:49 PM
blow air in it.........it will only keep siphoning if it keeps the flow, disturb the flow it will stop
BLDun
07-05-2007, 07:20 PM
thanks
