mdacton
07-04-2007, 11:07 PM
anyone running one?
I would rather go that route than trying to use a shield......the tunnel is tight as it is
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_37436_-1
revtime
07-05-2007, 02:49 AM
I run an ultrabell on my Rossler TH400.
It fit fine in my 94 except for the 2nd bolt up on the drivers side. It takes a little massaging or if you can do it pulling the trans/motor combo towards the passenger side to get the itsy bit of clearance you need to get the bolt in or out.
Keep in mind the ultrabell will save your floorboard and tootsies if the converter and/or flexplate come apart but you will still need a trans shield or blanket to be NHRA legal. The ultrabell won't help if the planetaries decide to exit stage left.
mdacton
07-05-2007, 07:44 AM
^^ thats the same bolt i'm having problems with.........
the trans cover won't be a problem, I just didn't want to go with the sheild for the flex plate, I was pretty sure it would not fit
