Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Meziere LS1/LS2 Electric Water Pumps On Sale!
Old Jul 3, 2007 | 09:58 AM
tbyrne's Avatar
We have the LS1 / LS2 Meziere electric water pumps on sale through July 10th!
The Meziere electric water pumps have been tested at the track, on the dyno and most importantly, during street driving. They have allowed engines to run cooler at low speeds and gain high end horsepower. In addition to the released power, you get to keep all of your factory accessories. Taking quality to the extreme, the WP319 features a dual bearing belt idler, billet parts throughout, and a “weather-tite” electrical connection. The pump is backed by a two-year warranty.
Features:
Purpose built for street use – 3000+ hour life expectancy.
Fully polished or anodized in your choice of 4 colors (Black,Blue,Red,Natural).
Chrome upgrade available.
55 GPM free flowing rating.
All stainless steel hardware included.
Heater and bypass provisions.
Light weight. Complete standard LS-1 unit weighs only 14.9 pounds!
Stainless steel large diameter main shaft with high performance ceramic seal.
Inlet fitting supplied to match stock configuration.
Easy install - truly a "bolt-on" pump.
Full two year warranty - the best in the business!
Finishing The System:
This pump is supplied complete with gaskets and hardware, complete and ready to bolt on. The only additional item you will need is a standard Chevrolet thermostat if you desire to use one. It will install behind the exit fitting located above the idler pulley.
Amperage draw:
Under normal use the pump will draw 11-12 amps.
Overall Height Dimension:
The standard pump is 7.88" long from the mounting surface to the tip of the pump.
Pump Weight:
This application weighs 14.9 lbs.
Sale price for all colors except chrome is $589.99 ($50. savings) This includes the required small block thermostat.
Other colors -
WP319N Meziere electric water pump (natural) with thermostat
WP319R Meziere electric water pump (red) with thermostat
WP319B Meziere electric water pump (blue) with thermostat
WP319PU Meziere electric water pump (purple) with thermostat
WP319U Meziere electric water pump (polished) with thermostat
Orders can be placed online or by calling 1-877-482-9763.
Have a good day!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
