Mike383LT1
06-29-2007, 10:40 AM
dont know if this is the right forum,but I'll try.I have a set of gm cast heads #3998920 All I can find is a year 72-75.I'm would like to use these on a 406 sbc and need to know if thier junk or can be made into something half decent.Thanks
jerminator96
06-29-2007, 11:03 AM
Well what I came up with was that they were used on '72-'73 350s and have 76cc chambers. That right there would tell me that they are too small for a 406. Then again, I'm no cylinder head guru.:)
Mike383LT1
06-29-2007, 12:03 PM
Yeah I did a little research thier your basic 76cc open chamber smog basically junk!
jerminator96
06-29-2007, 12:55 PM
Well even if they were the good stuff from around 69-71 I would think that the ports on heads designed for a 350 would be too small to feed a 406. I could be wrong though.
MachinistOne
06-29-2007, 09:36 PM
They will not make good power. Go aftermarket - heads are cheap these days.
96capricemgr
06-30-2007, 12:09 PM
There are no OEM heads for a smallblock from before the late 80s worth anything more than scrap iron unless you want a numbers matching setup.
The late 80s L98 heads will cleany outdo the 202 fuelie stuff and the LT1/Vortec stuff puts them to shame, hell they outdo the GM "Bowtie" race heads from the 80s. As said the aftermarket has a LOT of inexpensive options too.
To bring a set of crappy 60s-70s heads up to running condition you will likely spend what a new set of Vortecs would cost and still have less potential.
mdacton
06-30-2007, 12:12 PM
I wouldn't bother with vortecs on a 406.
Do some research and buy a good head aftermarket that will get you where you want to be
Mike383LT1
06-30-2007, 12:25 PM
Thanks for the input guys.I will be going aftermarket on the cyl heads
SStrokerAce
07-01-2007, 01:00 PM
For a out of the box head, look at a Dart Platinum or the New Pro 1's they are the best as cast out of the box heads for a SBC. Best bang for the buck by far. In the end you will spend the same money on a set of heads as you would getting those junk stock castings to work.
Bret
96capricemgr
07-01-2007, 02:59 PM
Just to be clear I was not trying to recommend Vortecs, just trying to make a point about how much it would cost to rework junk as opposed to how affordable some of the newer better stuff is.
The Vortecs offer limited intake manifold selection and I believe some slight header complication, great BUDGET head for mild stuff but for something like this the aftermarket has a lot to offer.
airflowdevelop
07-02-2007, 12:01 PM
Bret
I'll second that emotion.
Mike....You're still alive!!
Call me sometime.
