Starting problems - 89 5.0 RS Manual
DemonKnight
06-27-2007, 10:35 AM
I hope this is the right place to post this. If not, mods please move.
I own a 89 RS 5.0 Manual Transmission. It has about 160k miles on it but still purrs like a kitten.... when it starts. Heres the issue: When I go out in the morning to start my car for work it starts right up. If I drive it long enough to get the engine temp to like 200 dgrees then turn off the car it wont restart until it has time to cool down. :confused: I can get a jump from another car and it will start but the portable battery chargers dont do the trick. I have been told that it may be the Neutral Safety Switch but havent had it replaced yet. The starter is new. Any help would be greatly apprecieated.
jayman350
06-27-2007, 12:39 PM
kinda sounds like Heat Soak on your starter. Check out Jegs or Summit for heat wrap blankets, they are pretty cheap iirc
DemonKnight
06-27-2007, 02:14 PM
Thanks for the reply. I used the search function and saw that ALOT of posters have this problem. As far as a quick fix, banging on the starter. I actually had a mechanic do that because he said it was "carbon buildup" which I found fishy since it was a new starter. Again, thanks for the reply. :bow:
DemonKnight
07-19-2007, 10:40 AM
I took the car to a garage and it turned out that it was the Neutral Safety Switch. The mechanic also ripped out a bunch of the old wiring for the alarm. It starts up every time now. Hope this can help someone. Thanks for the reply Jay.
jayman350
07-19-2007, 11:26 AM
glad it was only the switch
gotta love it when its something as simple as that
Z28SORR
07-19-2007, 12:38 PM
Got me confussed??? Sticks don't have Neutral Safety Switches. Are you talking about the clutch pedal switch?
