I cant find a good cold air intake anywhere!!
Old Jun 26, 2007 | 04:03 PM
MyNameIsMud's Avatar
Any help availible?? plllease i drive a 91 z28 5.7 and i cant find one anywhere except some cheap ones. is there one anywhere??
Old Jun 26, 2007 | 04:13 PM
Dave89IROC's Avatar
not going to find much, I would do the "ram air" thing, or at least cut the bottom off the stock air boxes
Old Jun 26, 2007 | 11:55 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
You dont need one. The stock Camaro TPI intake is one of the best setups out there. The best thing you can do it cut out the plastic pieces underneath the air filters to make them fully open.
Old Jun 28, 2007 | 03:32 PM
its funny you say the cutting thing... i didnt even read about it on here i was putting in some filters and i kept diggin deeper i looked at my buddy we just smiled and started cutting stuff haha... would the ram air be more afficiant than stock??
Old Jun 28, 2007 | 05:45 PM
Dave89IROC's Avatar
the "ram air" I mentioned involves ducts that go down from the stock air boxes(with bottoms cut off), down to behind the foglight openings
Old Jun 29, 2007 | 02:58 AM
91Z-28's Avatar
That is contrary to the results most people have come to after back dyno tests, one with the airbox connected and one without. The stock TPI intake is extremely restrictive. Look at how narrow the tiniest part of the "neck" going from the airbox to the TB is. At WOT the "neck" can also be sucked flat.
Old Jun 29, 2007 | 03:33 PM
5.7 IROC-Z's Avatar
you would need alot more than 5.7l to suck that hard plastic intake "flat"
Old Jun 30, 2007 | 02:16 AM
91Z-28's Avatar
Ok, maybe not completely flat but a modified 350 can pinch it a little. If you cut one up you can see that the inner diameter is also not nearly as wide as the outer diameter.
Old Jun 30, 2007 | 01:01 PM
point is im trying to find the best way to run my intake system and im still not sure on what to do
Old Jun 30, 2007 | 01:05 PM
mdacton's Avatar
stick a filter on the end of the TB.....the stock box is junk
you WILL pick up by just using the filter on the end, I don't want to hear any crap about hot air either......More air is better than less, and air inlet temps are not going to be as much of a difference for the power you gain by having more air.
Old Jun 30, 2007 | 09:37 PM
ws6transam's Avatar
http://www.skulte.com/ramair.html
Yer welcome
Old Jul 1, 2007 | 04:05 PM
Zepher's Avatar
This is one of the best looking and performing ones,
I should have kept this SLP part since it is now very hard to find.
Old Jul 1, 2007 | 04:15 PM
91Z-28's Avatar
Is that the one for Firebirds only due to the battery location on a Camaro? Or wait....was it the Firebird that needed to have the battery relocated?
Old Jul 1, 2007 | 09:51 PM
Zepher's Avatar
Battery needed to be relocated for both cars since there are airboxes on both battery trays.
Old Jul 2, 2007 | 06:39 PM
Where can i find one of those SLP intakes at now days??
