Well I know June really isn't the time that you would set a new best, but I did and I couldn't believe it. On Sat night I went to my local track to get some practice for next weekends pts race. I wasn't expecting much and got a 6.87 in the 1/8, about what I was thinking, but I also know that the first pass is alway junk. The next pass was a 6.81 with a 1.42 60ft and the front wheels about 18in off the ground, that continued for the next few passes and then on the last pass of the night I had a 1.41 60ft, my buddy said it looked like the front tires were at least 2ft off the ground, and I shifted into 2nd gear while the front end was still in the air and ran a 6.79. I can't wait to see what it runs this fall.
Randy
tireburnin
06-25-2007, 11:32 AM
Those are some impressive times. It should be incredible once you get some zero DA to run in.
The Engineer
06-25-2007, 03:16 PM
Those are really great 1/8 mile times and according to my calculations they would be 10.60s in the 1/4! I assume they are all NA as well.
WD
Ya, it's all motor and I believe that there is more to be had in the topend of the tune, but you guys know how it goes, alot of trial and error.
Randy
bombebomb
06-25-2007, 04:59 PM
Very nice times ull be doing excellent in the fall.
mdacton
06-25-2007, 05:03 PM
Damn.....thats good
I guess you got the trans issues worked out.....
:thumb:
AutoRoc
06-25-2007, 05:47 PM
great times!
my 10.60 pass shows 6.77 in the 1/8th to give you an idea.
The Engineer
06-25-2007, 06:54 PM
great times!
So, my calucations were correct! He has a 10.60 car and that is serious fast for a NA LT car!
WD
CamaroRacing12
06-25-2007, 10:26 PM
sick times.... i want ur setup!!!
97bowtie
06-29-2007, 05:14 PM
Great times! It sounds like a little suspension work may be in order to keep that nose down.
It's kind of hard to keep the front down on a stock suspended car. I have try travel limiters later, but to really keep the front down you would really need to backhalf/4-link it and I'm not there yet.
Randy
AutoRoc
06-29-2007, 06:36 PM
Front end limiters will work fine with some trial and error. What compression and how nasty is that cam? Just wondering if this is a streetable combo, engine wise. I'd love to try 5.13's and a th350/30" slicks sometime, not sure if I could get them to fit.
The compression is 12:1 and the cam really isn't that big, 249/254 @.050 .621/.621 lift. You should try the gears and tires I love them, and I didn't have much trouble at all getting them to fit.
Randy
