installed pro kit, now which header's
Just got the eibach pro kit on my car, it looks nice and rides even better. I'm running out of mods to do, I think headers are next. Which long tubes will give me the best ground clearance for a daily driver commuter?
There are about 10 brands of LT headers for F-bodies... some of the more common ones include:
Dynatech, Kooks, Pacesetter, Hooker, etc.
As long as you're getting a 1-3/4" primary, they should all make around the same peak power. However, the longer the header, the more torque it will make (shoot for 32-34" headers)
Mike
Mike
There's not a major difference in ground clearance unless you include SLP headers on the list. Pacesetters aren't bad if you want a budget header. Otherwise, a QTP or Kooks header are nice stainless pieces. The trick is probably going to be in mounting the y-pipe. My mechanic suggested flex couplers off of the collector to go with my Pacesetter y-pipe.
as long as you don't get a set of the SLP long tubes, you will be fine. I went for a set of the dynatechs with their catted y-pipe. Great stainless headers, welds are good, and best of all, the instructions are really idiot proof.
Man, i really don't want to be 'that' guy, but i have those same headers available if you are interested. They are in good shape, the ypipe might be show some scuff marks because of a few speed bumps. I never slammed them hard but always took the bumps at angles. Also, i think the cats might need to be replaced.
I know its doesnt sound new, but, i'll get rid of them for a good price. PM if your interested. I got some pics if you want them.
So, if you do go long tubes, pacesetters are a good value for mild steel. I think the kooks are a bit over priced and the SLP are out of the question with that drop.
LAterZ!
LAterZ!
Hookers and Jethots fit great without any clearance problems. When I got done with the install on a buddy's car I could stick my finger between the y-pipe and everything that it was close to. And his is lowered and had no ground clearance issues either.
interestingly, some have seem some actual lose of efficiency when going to long tubes and a rear mount turbo. Long tubes would be great with an Procharger or a KB, but that is it unless you want to go N/A plus spray!
Dec 1, 2014 08:08 AM
