Wicked 97TA
06-23-2007, 03:50 PM
I've been hearing a loud whistling sound when my car is running. I was looking at the AIR pump today and the short 90* tube coming off the side of it is just there with nothing on the end of it. Is is supposed to be like that? My car is a '99 and it had a high flow lid on it when I got it.
'02 WS6
06-25-2007, 11:43 PM
Mine did the same thing, I had the supplied filter for the hose, which was tucked behind my proportioning valve. But I had pacesetter LT's & TD's installed so no more AIR provisions. I pulled the fuse for a couple of weeks, because it was driving me crazy, and making my volts bounce. Then I just removed it all together, and had the SES codes tuned out for good measure. (Never threw any, but they usually do.)
teke184
06-26-2007, 02:36 PM
not sure what elbow you're talking about.
but the air pump should only run for a few minutes after start up.
pull the fuse and see if the sound goes away...if not...it's something else.
alhtough the lid could easily cause a noise...that's part of the fun
