underdrive pulley and lightweight battery?
camz28aro
06-22-2007, 01:26 AM
I just got an ASP pulley (not installed yet), and want to see if anybody on here has a UD pulley and running a lightweight battery. My car is an auto but would put it in neutral when stopped. I was thinking about getting a hawker genesis gp26 that is 10-12 lbs lighter. Thanks.
teke184
06-22-2007, 07:58 AM
for the added hassles...and chances of getting stranded...WHY?
they are for track use for a reason.
stick with a regular battery.
AL SS590 M6
06-22-2007, 08:22 AM
I'm running a Odessy PC680 with 10% underdrive SFI balancer. It's a track only car but I haven't had to charge it or jump it at the track, yet.
And why? It weighs 14 lbs.
Kraest
06-22-2007, 01:48 PM
Battery is kinda pointless, but the ASP underdrive set is worth around 7rwhp.
2000GTP
06-22-2007, 02:34 PM
If it is a street driven car, I would just stick with a standard battery.
AL SS590 M6
06-23-2007, 04:47 AM
Unless you're trying to go fast at the track then it all adds up.
camz28aro
06-25-2007, 04:26 PM
thanks AL SS590 M6,I'll go with the lighter battery. I know I am not going to feel anything from the 15 lbs less but I bet I would feel the 100+ lbs I will have taken off total after this battery which is a good .10-.15sec. Also I want to get it closer to 50/50 and mount it in the rear. Maybe a k-member, headers, and a-arms in the future.
AL SS590 M6
06-26-2007, 05:50 AM
Can't put the little battery in the rear. Too much cable required to get back to the front will eat up all your power.
Little battery in front.
Or normal battery in the rear.
camz28aro
06-30-2007, 12:54 PM
http://www.gotbatteries.com/Productpage.asp?ProductNum=37L107S2
this is the battery I am going to get. Its about 12 Lbs lighter than the one I have now, Is it strong enough for it be mounted in the back or still too much voltage drop? thanks.
psychocabbage
07-02-2007, 07:34 AM
If I ever need a $160 battery for a car, then I know I am in too deep.
Wow.
AL SS590 M6
07-03-2007, 06:35 AM
You lose 12lbs. with the light battery and add 20lbs. of extra batery cables. What's the big push for moving the battery?
camz28aro
07-07-2007, 09:27 PM
You can find the battery for like 130.00, I need a new battery anyways so whats another 50 bucks to lose 12lbs off the front.
DonutMachine
07-09-2007, 10:24 AM
optima yellow cost 200
