Put the car on the dyno yesterday
AL SS590 M6
06-21-2007, 08:13 AM
because of a no shift problem. Thought we had it resolved but that's another story that can be found in the drivetrain forum.
Made a power pull to check the afr after the Darts and the 90/90.
It made 397.5 hp and 331.4 tq on a Mustang dyno with the torque converter unlocked.
At the track last night on the one clean pass that I made it ran 11.12 @ 120.73 with a DA of around 2800'. Not to shabby when you look at the number in my sig and it was at a DA of 700'
SSpdDmon
06-21-2007, 09:58 AM
Nice...Sean's a good guy. Got me to re-think the way I tune. :D
robvas
06-21-2007, 01:39 PM
What cam are you using?
AL SS590 M6
06-21-2007, 08:01 PM
APE custom grind. 228-236 .600+ lift with the 1.75 rockers 114 ground 2 degrees advanced.
Kraest
06-21-2007, 11:22 PM
Good numbers for an auto. Which Darts? Hopefully the 225s ;)
The 205s were only around +15 rwhp over my buddies stock LS6 heads when he put them on his 6-speed Z06.
AL SS590 M6
06-22-2007, 09:33 AM
Yeah auto, unlocked converter and Mustang dyno.
Dart Pro 1 225s, Fast 90, PRC 90 were the changes for this year.
And for those that might get a PRC 90mm throttle body. Do yourself a favor and open up the IAC hole before you install it. My car wouldn't idle after the swap so I took it to my tuner thinking that it was in the tune. He took the tb off and opened up the openings a little, put it back on and it started up and idled with no tuning needed.
