Loony
06-20-2007, 04:44 PM
Like the title says, do I need both? Can I get away with just the motor?
Do I need a new window motor AND regulator?Loony 06-20-2007, 04:44 PM Like the title says, do I need both? Can I get away with just the motor? 2001NBMZ28 06-20-2007, 05:36 PM Just the motor in my case, got slow then finally just quit. shoebox 06-20-2007, 06:21 PM It depends on what your problem really is. :) No way to know with what has been posted so far. Loony 06-21-2007, 01:51 AM Well, I press the up switch and nothing happens. It slowly died out. :) jhoo15 06-21-2007, 07:37 AM I have a 1981 Camaro that has a V6 engine that I want to replace. I recently purchased a LT1 engine out of a 1995 Camaro can some give me details on what I need to do to make this work: Will I need a need cross memeber and mounts; Will transmission work; what type of radiator will I need, etc..... shock6906 06-21-2007, 08:56 AM Well, I press the up switch and nothing happens. It slowly died out. :) Sounds like you're just in need of a new motor. Time to go to Advance. Loony 06-21-2007, 02:57 PM I have a 1981 Camaro that has a V6 engine that I want to replace. I recently purchased a LT1 engine out of a 1995 Camaro can some give me details on what I need to do to make this work: Will I need a need cross memeber and mounts; Will transmission work; what type of radiator will I need, etc..... You should probably start by making your own thread. :p Thanks shock! | ||
