beeker82
06-19-2007, 12:32 AM
I just got pulled over for no headlight,so this makes the 5th time in less than a year that they needed to be replaced:mad:
pos headlightsbeeker82 06-19-2007, 12:32 AM I just got pulled over for no headlight,so this makes the 5th time in less than a year that they needed to be replaced:mad: GreenDemon 06-19-2007, 12:13 PM What headlights do you buy? I only had one go out in the three years I owned my 95. Z28SORR 06-19-2007, 02:31 PM Carefully check the connectors, wires, and grounds for corrosion. This can cause the system to draw more amps. and shorten the life of your lights. You can buy a multimeter accessory that clips around wires and measures amps. | ||
