horse-power400
06-18-2007, 11:12 PM
Im buying some pace setter race style long tubes they're going on a 95 Z28 do I need some O2 extensions if so where is the cheapest place to get them? Also where can I get the block off plates for the intake? Im thinking about buying the 3in. universal X-pipe from summit does it require any bending or can I just bolt it up? Because I don't think any muffler shops around here have equipment to bend 3in pipe. Will some dynomax ultra-flo 6" round mufflers fit. I was wanting to put flowmaster 2 chamber 40 series mufflers but I think I would have clearance issues.
97ramairta
06-18-2007, 11:23 PM
look on ebay for the block off plates...maybe $25 bucks max...i paid $20 shipped for mine, and the o2 extensions should be there too, if not just do a search for casper electronics LT1 O2 extensions...
SS MPSTR
06-18-2007, 11:53 PM
heard horror stories of late on the Pacesetter headers...a torch and a chain may be needed in your toolbox to get the collector into the right place....just sayin'.
JoeliusZ28
06-19-2007, 08:50 AM
explain??
If youre talking about the driver side collector I smashed my floorboard up .5" and ran a 2.5" y-pipe after the collector. It only hits the floor board once in a rare while on the ocasional Spec chatter-spell which are amplified by my worn motor mounts.
This was the only "issue" i had with my pacesetters. Im very happy with them, youre going to run into snags no matter what brand you use IMO.
2000GTP
06-19-2007, 12:54 PM
The 02 extensions should cost pretty much the same anywhere. They usually run around 20 bucks a piece.
horse-power400
06-19-2007, 02:29 PM
Thanks, I found the block off plates and o2 extensions on ebay. Still wondering if the universal 3in. x-pipe will work without having to bend it.
Firebird_fr3ak
07-12-2007, 01:22 AM
http://www.lt1engine.com/techaids/trueduals.html
