Is my car too Low.....
AprilZ
06-18-2007, 10:40 PM
Dont start throwing flames at me..I DID do a search!!!
My husband and I want to do true duals on my 99Z. The price isnt too much of an issue and I have someone in mind to do the install. The problem is my husband recently bought me some 18 in C6 chrome wheels and lowered my car accordingly. We were wondering about the clearance issues now. We lowered it 1 1/2 in back and 1 1/4 in front and there doesnt seem to be enough clearance for 3 in duals with turn downs before the axle. Anybody have their car lowered significantly with duals? Our exhaust guy said it would work if I went with 2 1/2 in duals but I really didnt want to go smaller. Any oppinions?
Also, I would like to have my 3 1/2 in tips fabbed in place for appearance purposes because my car is mostly show. I know they cant weld a hanger to the gas tank though... so is this possible??? Thanks in advance for any help or suggestions.
mdacton
06-18-2007, 10:49 PM
dual 2.5" pipes will support more h.p. than you have.........
You want to put tips on the back that aren't hooked to anything? thats frikkin gay....
Get a y-pipe and cat back......these cars aren't made for duals. the cat back/y-pipe will flow good and even out pulses
AprilZ
06-18-2007, 10:55 PM
I already have "frikkin" Hooker Long tubes and ORY, into SLP Loudmouth muffler. I'm not concerned about HP, I really just want the sound that I've heard on many other Z's in the area with true duals. I'm not worried about if someone thinks the tips are gay either, thats what I want. I was just looking for some help, not back lashing :(
mdacton
06-18-2007, 10:56 PM
Back lashing?
what do you want to know.....the muffler man told you go with the 2.5"...go for it
AprilZ
06-18-2007, 11:02 PM
How much would this effect my torque? Can I still have my tips? Would it be better to go over the axle or before??? These are a few things I want to know.....
hosspwr94
06-19-2007, 01:22 PM
The 2.5" true duals will actually help your torque, the 3" will hurt the torque due to no backpressure in the line. I know this from experience! Unless you have 600+Hp 3" is overkill and will kill all your low end torque. As for your tips, you do what you want to! I prefer the dump before the axle but that's my preference.
Hope this helps!
Vamp
06-21-2007, 12:16 AM
You are lowing your car, so over the axel would be preferable. You mentioned cost doesnt matter so looks like that would be the way to go. Under the axel is generally easier for the shop and should cost less. Works fine for a car that's not lowered. You should pick up some torque, probably wont notice it much though on a stock head/cam car. 3 inch duals would be utter overkill for your car, 2.5 in is fine. I thought 3 1/2 in tips were for hondas? :confused:
AprilZ
06-21-2007, 09:08 PM
The 8 in tips are Honda issue, hun.:p Mine look great, A LOT better than the stock ones see:
http://i152.photobucket.com/albums/s179/1hot99z/Lowmaro3.jpg
Vamp
06-21-2007, 10:13 PM
Looks good, is that your car? I've not really been a fan of large tips, but those do look nice. Slash cut ones are my favorite too :D What did you decide to go with for the exhaust? How do you like the sound compared to the LM you had before?
Right you are ;)
mdacton
06-21-2007, 10:16 PM
those tips look fine..........On a truck!
AprilZ
06-21-2007, 10:32 PM
Cheap shot ^. Bend over and I'll show you where else they look good ;)
I like it and it sounds fuggin Awesome!
I haven't gotten the duals yet but I will probably go Bullit or 1 chamber flows.
mdacton
06-21-2007, 10:46 PM
bullets are too loud......flows=slows
get a good cat back.....and get rid of the dump truck tips
turnin20s
06-24-2007, 10:05 AM
IMHO if you want true duals and money isn't an issue.......Bassani is the exhaust that you want. 2.5" ture duals over the axle and then you could still use you tips.....not that I would suggest it, but whatever floats your boat
Greed4Speed
06-24-2007, 10:23 AM
If thats what your car looks like lowered, then it looks like you have room to me. The low spot will be up front where your Y pipe is anyway. For mufflers I'd suggest Pro-Flo Twisters. Not as loud as and smoother sounding than bullets. Or you can get some Magnaflows like Teke runs.
I'd run 2.5" dumped before the axel w/no tips. Makes for a nice clean appearance. If you want out the rear, just have them flange where the dumps would be so it can be removed and run them under the axel and out the rear. It isn't my car, but I also don't care for the fake tips idea.
Look on LS1tech in the exhaust section. There are tons of pictures of duals.
reamo04
06-24-2007, 01:52 PM
personally, if it is mainly for show, i would go over the axle. Flowmaster 1chambers are a good choice too, sound good and flow good too
Crows89RS
06-25-2007, 05:30 PM
It's not too low to do true duals... but you WILL have to use bullets and it'll have to be custom fabricated to tuck up under the car next to the driveshaft. And you don't need the turndowns directly at the ground, mine are angled down and to the side of the car. I have true duals, but not an x pipe, so it just runs down the side of the car. My car, not being lowered, is probably in the same boat as you with a lowered car and trying to run true duals. I've only scraped a few times, I'm very careful about it.
And I second the 2.5" thing. GO with 2.5".. i noticed a lot less torque with 3" true duals than I had with my 2.5" flowmaster catback. Plus 2.5" duals will be cheaper.
AprilZ
06-26-2007, 09:45 AM
^ So you have straight pipes from the headers back? Is that better than the x/h pipe setup?
Vamp
06-26-2007, 10:19 AM
The X/H pipe will increase the scavenging effect for your exhaust pulses. This has been proven to add some HP, but usually isn't anything considerable. I run duals without an X/H pipe due to the fact I didnt have room for what I wanted done. It all depends on what kind of muffler(s), if you run a cat, and where you end your pipes. If you have the room, do an X pipe. It will also smooth out the sound of you exhaust as well.
AprilZ
06-26-2007, 02:27 PM
Thanks guys, I appreciate the help. I would like to run an x pipe into Bullets and then turndowns before the axle....no cats. I just have to run it by my exhaust guy and give him a wad of cash. I'll let you know how it tuns out. Thanks again!:)
