door lock/unlock button wont work on both sides
afr lt1
06-18-2007, 01:44 PM
My lock/unlock switch on both doors wont work. I read in the manual that the key has to be in....well that doesn't make any difference, it still wont work. The switch makes no noise what so ever when pressed in either direction.
-it worked fine for the first few yeas of owning it, then at some point it stopped.
Also, my key fob unlock/lock buttons dont work hardly at all. My driver door will unlock after I press it like 5 times(but wont lock). The passenger side will only lock when I press *unlock*.... I know that sounds weird, but that is what it does.
Thanks in advance.
Compstall
06-18-2007, 11:23 PM
Follow the electrical schematic to where the switch wiring for both sides meet. Find something in common with both sides. I don't have access to my schematics right now or I'd be of more help.
As far as the key fob goes, have you tried swapping in a new battery?
afr lt1
06-19-2007, 08:33 AM
yup, i have tried new batts. I also tried two different key fobs and they give the same result.
Lunch Box
06-19-2007, 09:30 AM
The contacts for the buttons on the key fobs can get gunked up over time; you can clean them with the hard pink pencil erasers; although your problems might be more than that
afr lt1
06-19-2007, 01:03 PM
nope, it has nothing to do with the key fobs. I do hear a little click from under the glove box when I press the button and nothing happens.
afr lt1
06-20-2007, 12:53 PM
bump. has this never happened to anyone?
Critter
06-20-2007, 04:42 PM
mine started doing it 2 days ago. i think it has somthing to do with the friction on the driverside locking mechanism. take off the door panel and try it see if it still sticks, then if it is see if there are any areas that are rubbing more than normal and lube them.
afr lt1
10-29-2007, 02:35 PM
Will both sides stop working if the drivers side switch is bad? OR is it only the passenger side switch that stops both sides from working?
Critter
10-29-2007, 04:53 PM
if one switch goes out the other will still work. i took my panel off and made sure everything was lubed up and it works fine now.
afr lt1
11-01-2007, 09:07 AM
NICE! I finally discovered the prob.:D I found a broken grey wire in the boot at the hinge of the driver side door. OMG, I cant believe I didn't find it sooner.
ALL IS WORKING!
Critter
11-03-2007, 09:30 AM
ALL IS WORKING!
makes life a lot better huh.
