BlackbirdWS6
06-18-2007, 09:22 AM
Tried looking and doing a bunch of searches but where is this thing? I have a 97 TA if that helps.
-Brian
-Brian
Where is the parking lamp relay???BlackbirdWS6 06-18-2007, 09:22 AM Tried looking and doing a bunch of searches but where is this thing? I have a 97 TA if that helps. -Brian BlackbirdWS6 06-18-2007, 07:59 PM ttt shoebox 06-18-2007, 10:34 PM There is a fog lamp relay and a headlight module, but I don't believe a relay exists for the parking lamps. BlackbirdWS6 06-19-2007, 08:29 AM Now I'm even more confused lol. Maybe you can help me a little bit. I've been trying to track down my front turn signals (LEDs) are not flashing correctly with the headlight switch in the first position (headlights down) and full on position (headlights up). My PnP leds I have are supposed to run white with the DRL and then switch to amber and back to white when using the turn signal. For some reason both are not doing this and it goes to a solid amber with the turn signal engaged. My rear LEDs in the taillights still work perfectly and I replaced the flasher just in case. I'm stumped as to what else to look at because it has to be something with the circuit and not the LEDs since both colors are still working. I went to pep boys and there was a parking lamp relay part number so I picked it up thinking this would fix my issue. What other components are capable of fault here that I can replace or look at. These work really well and it stinks I'm having this issue now. Here is a video of how they should work and were working. http://video.fquick.com/thumbs/2071.jpg (http://www.fquick.com/videos/LED_Switchbacks/2071)View Video on FQuick (http://www.fquick.com/videos/LED_Switchbacks/2071) | ||
