pyro719
06-16-2007, 10:47 PM
I am about to get pacesetter longtubes and was wondering how much power I would lose by going with the 3 inch ORY with single muffler dumped before the rear axle VS xpipe true duals dumped before axle?
Ory Vs Xpipe?pyro719 06-16-2007, 10:47 PM I am about to get pacesetter longtubes and was wondering how much power I would lose by going with the 3 inch ORY with single muffler dumped before the rear axle VS xpipe true duals dumped before axle? 97ramairta 06-16-2007, 10:52 PM its all depends and what supporting mods you have. running true duals depending on the mufflers you have might not be enough back pressure resulting in crappy performance. pyro719 06-16-2007, 10:59 PM I just have the mods in my sig.I plan on getting a mail order tune once I get the headers. I thought the ORY would be easier and cheaper and still provide modest gains? Jared 3870 06-16-2007, 11:05 PM For you basic bolt on car both setups provide nearly identical performance gains. The only real advantage to true duals is the sound, and by that I mean that it sounds like a V8 should. 97ramairta 06-16-2007, 11:17 PM whenever i had my longtubes and exh. put on i ran open headers for a couple days before my app. to get the rest put on (i did the headers myself) and it ran like **** bc of no back pressure. once the rest was put on it was just fine. oh yea i ran a custom ORY and loudmouth Jared 3870 06-17-2007, 02:34 AM Less backpressure does not equal less performance, this has been discussed many times over. The poor running you described was probably due to the fact that your O2 sensors were right at your collector ends, and while running open headers they were able to be exposed to fresh air at times instead of exhaust, causing erratic fueling/mixture problems. Basically the car was not able to moniter what the motor was doing and was trying to correct for an extremely lean condition or something of the sort. tnmotown 06-17-2007, 03:13 PM http://i154.photobucket.com/albums/s278/tnmotown/exhaust.jpg Mods are in my sig, shooting for 400RWHP after tune. Never ran true duals before but this setup seems fine to me. (a little too loud now after motor swap) If you just have the mods that you listed then you should be fine with the LT's,ORY and dumped pyro719 06-17-2007, 07:17 PM What kind of muffler is that? I need some recomendations on a single muffler for my new ORY. Im looking for something that flows well but is still fairly quiet at a decent price, Anyone have any good ideas? 2000GTP 06-17-2007, 09:08 PM What kind of muffler is that? I need some recomendations on a single muffler for my new ORY. Im looking for something that flows well but is still fairly quiet at a decent price, Anyone have any good ideas? So you are just going to have a muffler put at the end of the ORY, or are you looking at an entire catback system? pyro719 06-17-2007, 09:48 PM Just a muffler and probly a small strait pipe off the muffler. tnmotown 06-17-2007, 10:41 PM its a spintech muffler but let me tell you its pretty loud. Even before my motor swap it was still kinda loud with the original 5.7L Im looking at getting a mangaflow bullet muffler and extend the piping a little bit more. pyro719 06-18-2007, 12:11 AM Do you think I could fit a summit turbo muffler in there? tnmotown 06-18-2007, 02:08 AM This is the one that im looking at. Im sure the summit turbo muffler should be fine in there as long it clears everything. The diameter on that Magnaflow bullet muffler is 4" and since my car is lowered 2" i dont have much space http://store.summitracing.com/partdetail.asp?autofilter=1&part=MPE%2D14419&N=700+4294923429+4294922711+4294922710+400636+4294 791977+115&autoview=sku teke184 06-18-2007, 08:13 AM "its all depends and what supporting mods you have. running true duals depending on the mufflers you have might not be enough back pressure resulting in crappy performance." :lol: what a newbie.... how many times has that been discussed?? ugh!!! i ran 3" duals, Xpipe, dumped with no mufflers for 6 months...had no problems with power. so tell me again how a lack of backpressure is bad?? in all honesty...a ypipe setup like you're talking would probably lose about 10hp in the top end compared to an Xpipe setup. probably not enough to worry about. soul strife 06-18-2007, 08:49 AM Backpressure? Who wants that? With the X pipe you will get savaging, this will create a vacuum on the exhaust valves and help pull out those gases. BassProCamaro97 06-18-2007, 09:28 AM You can do a search and do some reading on back pressure, but I'll save you the time. It doesn't matter. The reason I went with a dual setup was because I wanted better options of mufflers as well as the sound of an old muscle car. It seems to me in most cases guys who do duals dump at the axle and guys that want pipes at the bumper do ORY and cat backs. Then there are the guys who do duals to the bumper but that’s expensive and time consuming. Its really preference and budget that’s sways you one way or another. I love my exhaust very pronounced. ~Jim~ Jared 3870 06-18-2007, 09:59 PM I love my duals as well. Minus the fact that they are harder to initially set up, it is well worth it in the end. The sound blows away any catback setup and people always ask you what exhaust you have. pyro719 06-07-2008, 04:54 PM Do you guys think I can gain any power with true dual setup over my pace setter off road y pipe? pyro719 06-08-2008, 08:00 PM anyone? Will a true dual setup give me more power than my pace setter ory with cutout? slomarao 06-09-2008, 05:23 PM pyro- no your not going to gain much with TD's than the ory. It will sound better but the power gains wont be there. If you had heads and cam it would be another story. Even on the n2o, the lt's with a cutout will be just as good. scavaging is what an x pipe really helps. This is where the gains come from. And all this back pressue non sense. You only need a small amount and at lot of it depends on the engine. Most people have no idea what they are really talking about when they mention this. They probably read some article somewhere and now think that its a must have. | ||
