FAST 92 dakota for cheap
Old Jun 15, 2007 | 10:30 AM
stevethepirate's Avatar
ok, i JUST bought this truck. the previous owner had told me it would pass inspection, but it didnt. it passed the carbon monoxide test, but not the hydrocarbon test or the nitrous oxide test. this is probably because of the gutted catalytic converter. It would also need a new gas cap.
That said, i just need to get what i have paid for this truck so that i can find something that will pass inspection. i have a camaro that i put all my money into, and my DD simply cant take away from that. otherwise, i would most certainly keep this truck.
All that i'm doing is copying over the ad that the previous owner had up (on another board) seeing as i bought it less than a week ago.
The bad:
-Heater Core needs to be replaced. At the moment, I am bypassing it so it does not leak. Has an electric heater at this moment.
-Needs CV joint on driver side up front ($60 part) + easy installation.
-Drivers door lock is iffy. You have to play with it.
-Tag light is missing. Should still be wired for a light though.
Here are the specs/info...
Miles on the body: 166k
Miles on engine: 75k
Drivetrain specs:
-'95 5.2L V8 bottom end
-Mopar Performance R/T 5.9L V8 top end components
-Mopar Performance R/T cam
-Mopar Performance R/T heads
-True double roller timing chain
-K&N FIPK with "functional" '70 Dart Swinger ram air scoops
-Underdrive pulleys (not installed - including an alternator with the underdrive pulley)
-Nitrous Express Dodge EFI wet kit (Adjustable from 35-250 .. 100 shot injectors in there at the moment),
-Screamin' Demon Coil
-8mm Accel wires
-Accel spark plugs
-Accel cap & rotor
-46RH (A518) transmission from a '95 Dodge Ram 1500 with 75k miles on it, shifts awesome!
-Chrysler 8 1/4 rear with 3.91's and a Suregrip (posi-type)
Suspension:
-Belltech 3" front and 4" rear lowering kit
-KYB gas adjustable (automatic) shocks
Misc:
-Vortex muffler with turndown (sounds real NICE!)
-Extang bed cover
-Sylvania Silver Star headlights
-GT Grant chrome/black steering wheel
-Sir Michaels roll pan
-LED "Line Of Fire" light bar
-Super White reverse lights
-REAR tint (not sure what %) only
-American Racing "Neptune" 15x7" polished aluminum rims (they are in need of some TLC)
-Yokohama Avid S/T 255/60-R15 rears and 235/60-R15 fronts (Almost brand new up front, decent tread in the back .. not sure but I'd guess 15/32?)
-SSBC "Short Stop" Slotted Rotors w/ High Performance Pads
-6 foot "short bed"
*Stereo system is NOT included*
With a 100 shot it puts 307 hp / 390 lb. ft. torque to the ground. It ran a 12.7 @ 108 in the 1/4 on 150 shot, 13.1-13.3 with 100 shot, and 14.1-14.4 N/A. Spray runs on drag radials and N/A was with street tires.
Im asking $3,000. I just need to get what I have put into it.
Old Jun 16, 2007 | 09:40 AM
come on... someone must be SLIGHTLY interested. this truck will beat most bolt on LS1's! N/A, it will give an LT1 a run for its money.
all it would need to pass an emmissions test is a catalytic converter... but not all counties even require it!
Old Jun 16, 2007 | 09:44 AM
a walker's Avatar
What exactly is a "nitrous oxide" test, and why would the emissions people be doing it?
Old Jun 16, 2007 | 11:55 AM
it has nothing to do with the nitrous that youre thinking of... its one of the gases thats emitted. a cat will fix it.
Old Jun 18, 2007 | 04:25 PM
evening bump!
Old Jun 25, 2007 | 08:50 PM
accepting trades. nice set of rims + cash?
Old Jun 27, 2007 | 04:25 PM
bump!
Old Jun 27, 2007 | 05:36 PM
jerminator96's Avatar
Just for your own info it failed the Nitric Oxide test or NOx, not nitrous oxide or N2O.
Bump for a nice truck though.
Old Jun 27, 2007 | 07:52 PM
lol. thanks for the info and the bump.
Old Jun 28, 2007 | 02:13 AM
94formula350's Avatar
needs a drivers cv joint?
is this 4wd?
also,interested in trade for a 94 formy?
a/c work?
Old Jun 28, 2007 | 12:06 PM
its not a cv joint... i forget what its called. its the equivalent for a rwd truck though.
so yeah, its 2wd...
A/C works perfectly.
cant trade for another fbody though... sorry.
Old Jun 28, 2007 | 10:44 PM
so yeah, its 2wd...
the equivalent in a rwd truck would be an axle shaft.
otherwise i have no idea what your talkin about that it needs,ball joint perhaps?
anywho...with the trade offer a nogo,im out of the running.
Old Jun 29, 2007 | 12:23 AM
i think its a ball joint.
(i would go for the trade, except i need something with a trunk! i definitely want a v8 though )
thanks for the interest!
Old Jun 29, 2007 | 09:47 AM
haha,take the bass tube out and its gotta trunk , i hadda supercharged 2001 fullsize ram,it got totalled and i miss the damn thing,so ive been tryin to get back into a dodge.
if ya find yourself interested let me know ,id be happy to send ya some pics.
btw its a dark green mettalic formy,runs like a champ{had an issue with the trans,but i got that figured out yesterday} seems the car had a computer put in it with a pcmforless tune,with crazy high shift points,i put a 94 t/a pcm in it...trans shifts like a dream haha. btw it runs 13.80s with a 2.2-2.3 60 ft
Old Jul 18, 2007 | 02:46 PM
bump!
