New Type of Engine Design
95 Z/28 LT1
06-14-2007, 12:41 PM
Anyone ever seen/heard of this? http://www.nevisengine.com/
Interesting concept. I wonder how long it will be before this catches on, or if it ever will. What's the downside?
camz28aro
06-14-2007, 01:33 PM
looks interesting, I want to see a video of it working but IMO it won't catch on.
jerminator96
06-14-2007, 03:24 PM
It looks pretty neat. The principles of it's operation seem to be solid. My major area of concern would be the amount of surface area in the combustion chamber. I was having a hard time seeing where everything went though, so maybe it's not as bad as it appears.
thesoundandthefury
06-14-2007, 03:43 PM
250HP@2,000rpm's out of 2 cylinders.
"However, as can be inferred from the table above, the NEVIS engine could run at nearly 3 times this level of rpms, yielding still more power – approximately 500HP"
Meh, it's okay I guess...
blue89rs
06-15-2007, 01:34 PM
250hp at 2000rpm would mean 656ft.lbs. of torque. whoa. I've seen engines similar to this that use multiple pistons on a sort of carnival ride looking deal. The pistons rotate on a drum of sorts around the "crank". Both the Nevis and the before mentioned rely heavily on a wave patterned piston guide cut in the sidewall. Seems to be a weak point.
