High flow cat??
ChevyTuffD.A.
06-10-2007, 06:14 PM
Ive been thinking about putting a high flow cat back on my car to try and deepin the exhaust tone a little. I loved the way the Borla sounded when I still had the stock cat on the car. Right now I am runnin an ORP. How much power would I be leaving on the table by puttin a high flow cat on the car?
2000GTP
06-10-2007, 08:14 PM
If you have alot of rasp in your exhaust note, then a cat should help clean that up a bit. As for power loss, you might lose a very small amount, if any.
89TramsAmGTA
06-10-2007, 09:01 PM
None if you get the new Magnaflow Metallic Substrate catalytic converters. They flow like 590 cfm apiece. That will support a lot of hosepower.
ChevyTuffD.A.
06-11-2007, 09:46 AM
Yes I am trying go get rid of some of the raspyness that came along once I took my cat out. I would rather have it sound good and give up a couple hp then to have it the opposite.
Z28LT1_Just_Nasty
06-11-2007, 12:47 PM
Put in a cat and install a cutout before it for the track. That's what I plan on doing once it comes time for inspection.
ChevyTuffD.A.
06-11-2007, 12:49 PM
Yea thats a good idea. I could just have them weld in the cut-out while they are installing the cat.
