Tim 97Z
11-27-2002, 06:56 PM
I have a 383 M6 with 4.11 gears. I am planning to add a 100 or 150 shot via a NX wet kit. The thing is, I do not want to spray in first gear. I know one option would be to put a switch on the shifter knob, but I would like to avoid that if possible. I would rather have something automatic. Does anyone have any ideas?
AutoRoc
11-27-2002, 08:55 PM
I guess you could try to do a microswitch along with the shifter, right?? When the shifter slams second gear, it would hit the switch activating the system. Your foot would also be controling the WOT switch for safety also. The switch would probably have to be visible because you would want to turn it off when you are done:D
Anyone ever do this?
Maybe train a monkey to ride shotgun and toggle the switch:D Goodluck
Or ge stickier tires and jsut spray first gear right out of the hole:teek:
Tim 97Z
12-01-2002, 07:37 PM
Thanks AutoRoc
There is already a semi-trained monkey in the drivers seat!
I understand that some of the control boxes, like the NX Maximizer or Jacobs can be set to only spray above a certain mph.
Any other ideas?
kirschman
12-01-2002, 07:59 PM
:think: Why dont you want to spray in 1st. Thats when its the most fun IMO. Not sure if ya got a 12 bolt or 9", but if ya do throw on some slicks and let er eat!!! If you dont have a after market rear GET ONE!! Most races are won by whoever has the best 60ft. sounds like your making all kinds of power why not use it to its FULL potential, spray in 1st!!!
RacinLT1
12-01-2002, 09:18 PM
The NX maximizer is time based only,cannot be set to go by mph.
Ed Blown Vert
12-01-2002, 11:30 PM
It would be better if you could hook up a switch so when you are in first, it would disable the N20. Then when you shift, the switch would release and arm the N20 for the rest of the shifts.
Tim 97Z
12-02-2002, 06:41 PM
Thanks Kirschman
I have a Strange 12 bolt, ACCPT Drive Shaft and Street Twin clutch, so I am not worried about the drive line. The problem is traction, even with the Nitto DRs. That is why I want the option not to spray in 1st. I would like the system to let me spray in first if I go with MTs (or become a better driver). I know the easiest way would be a switch on the shifter, but that is just someting else you have to mess with.
rpm4lalo
12-02-2002, 07:58 PM
What you described with the microswitch wouldn't work. When you shift out of second, the circuit would be broken.
I am sure it could be done with a different type of switch though.
The way I go about not spraying first is use a WOT switch under the hood, and a Hurst T- Handle shift knob with a momentary pushbutton. I have 4.11's and an M6 so it is tough enough to launch the car. Spraying in second also help me protect the rear end to a certain extent.
Once I have engaged second gear at WOT, I depress and hold the button to spray. Once I reach 5800 rpms I release the pushbutton and shift. Etc., etc.
I don't currently have a window switch in my system, but one could be added in case you miss a shift and to protect from accidently spraying too low or too high. The safety device I have is my FPSS.
all that would be needed is a micro switch for first gear when in 1st gear it stops the current then once he shifts to snd then gives it WOT it would spray.. basicly ur wireing it backforwards
