Where to find breslim header bolts?
onetransam4u2nv
06-04-2007, 05:56 PM
Ive looked all over for breslin header bolts for the lt1 which no luck everones seems to discountinued them. any help would be great.
useful_idi0t
06-04-2007, 07:24 PM
i ran into the same problem last year trying to get some for my header install that never happened. could not find a single vendor that carried them. if you find some let us know:D
2000GTP
06-04-2007, 07:25 PM
Last I heard, they shut down. You may be hard pressed in finding a set.
ttop1986
06-04-2007, 07:33 PM
I think I got mine from Victory Racing Engines over a year ago.
wrd1972
06-04-2007, 07:47 PM
They are no longer made, next best thing is stage 8's, they re a SOB to install but they work well.
onetransam4u2nv
06-04-2007, 08:13 PM
dam that really sucks
96capricemgr
06-04-2007, 08:24 PM
Be vigilent tightening the bolts frequently for the first couple weeks. Bolts don't loosen till the gasket compresses and causes a lose of torque on the bolt at which point they can begin to loosen.
You guys looking at fancy bolts are halfassed treating the symptom rather than the problem.
Repeatedly tighten the bolts as the gaskets compress from the initial heat cycles and the bolts will stay tight after that.
SevenStars
06-04-2007, 10:17 PM
I got a set with 1k miles on them I pulled off my parts car... if any ones interested pm me an offer I guess
1997Z
06-04-2007, 10:51 PM
What size do you need?
RUDEDOG
06-04-2007, 11:39 PM
I used stainless allen head bolts from home depot with flat and lock washers and they have never loosened up.
Steve in Seattle
08-19-2007, 07:23 PM
Breslin is MIA... went belly up.
Stage 8's are crap, you can't even get the lockers on every bolt with most LT1 headers.
ARP 12-point 1.5". Tighten twice and you're money. :)
