abs light
Old Jun 3, 2007 | 06:15 PM
Geezer powered's Avatar
abs light
Anyone care to take a stab at this one? My abs light has come on? What is most likely it? The sensor on the wheel hub or at the abs unit?
Old Jun 3, 2007 | 06:48 PM
green.Z's Avatar
My vote would be for the sensor at the wheel.
A Chevy dealer I used to work with (before they went out of business) said that they had never seen an ABS unit go out. Unfortunately, my mechanic at the time convinced me to buy another ABS unit. My problem was actually the master cylinder, we couldn't get the system to bleed.
If you do end up needing an ABS unit, I have one that should be good that I could let go for a deal.
Old Jun 3, 2007 | 07:33 PM
Sweet.......... I'll give the wheel sensor's a shot
Old Jun 3, 2007 | 07:56 PM
ricehammer's Avatar
Also check the connectors to the ABS box. Had the same problem on another car, changed the hub. Problem came back, checked both front hubs for output with a multimeter set for AC and they were fine. Pulled the connector to the ABS box, plugged it back in and the problem was gone for a while. Checked the connector and one of the wires was loose from it's pin.
Old Jun 4, 2007 | 09:13 AM
OBE1 95Z28's Avatar
If you're running headers the ABS wiring to the wheel sensors is prone to heat damage.
Old Jun 6, 2007 | 12:28 PM
97formulakid's Avatar
Don't mean to highjack the thread but might light has been coming on too. But, it seems to never come on until i do a hard launch on the slicks. ANy ideas?
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
