Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
changed Rad and Thermo now misses and pops...
Old Jun 1, 2007 | 07:53 PM
retromek's Avatar
I searched for the answer through the threads and it seems there is a connection between changing a thermostat and then the engine begins to misfire run rich and ping I have a 94 z28 the ses code stays on.
What did I ****-up?
Old Jun 1, 2007 | 08:25 PM
mdacton's Avatar
find out whats codes you have.....
you didn't get water on the distibutor did you?
Old Jun 1, 2007 | 08:26 PM
retromek's Avatar
I'm sure I did.
Old Jun 1, 2007 | 08:29 PM
mdacton's Avatar
Originally Posted by retromek
I'm sure I did.
well....get the codes...maybe try to blow it out if its vented, and then probly need a new opti.....
No big deal, it happens
Old Jun 1, 2007 | 08:39 PM
retromek's Avatar
Yeh I figured ... Is the MSD unit from summit ok? Or wich opti is the most used as a replacement?
Old Jun 1, 2007 | 08:40 PM
mdacton's Avatar
factory/GM one
Old Jun 1, 2007 | 08:42 PM
retromek's Avatar
I'll go pull the codes
thanks for the info
MyfateZ28
Jun 19, 2015 03:42 AM
captcorvette
Mar 7, 2015 12:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
