If you know any thing about 3.1's see this.
Old Nov 27, 2002 | 02:23 AM
oil pan 4's Avatar
Exclamation If you know any thing about 3.1's see this.
I need every useless and important number you can come up with for the 3.1's.
Here is a list but others are welcome.
Bore, stroke, compression ratio, Head volume, deck hight, piston pin hight, deck clearance, normal vacuume (inches Hg), main jornal, rod jornal (2.000'' I think), piston pin dia (.912''?), port volume, max valve lift, piston type (dish, flat, dome?), fuel PSI, normal compression test pressure, TB diameter, timing, injector info, cylinder head gasket thickness, Ignition info, valve sizes and any weight, mesurement or reading you can come up with.
Old Nov 27, 2002 | 06:43 PM
blue95's Avatar
I honestly don't know about a 3.1 but
www.thirdgen.org
and look for a guy name johnny00v6a4 over at fbodyv6.com he is a old 3rg gen guy. I just thought I would try....
You may already know this stuff but I thought I would try
cmsmith
Apr 30, 2015 05:18 AM
Hal Fisher
Sep 14, 2002 09:36 PM
