05-24-2007, 12:40 PM
i have a strange issue with my power steering. I guess it's nothing that i can't live with but it's wierd.
first let me say:
the pump doesn't squeel
there are no leaks
the fluid isn't low
the steering wheel is easy to turn
the steering doesn't cut out
none of the usual problems that people complain about.
MY issue is that when you turn the wheel to make a sharp turn, say from a stop sign or something, you actually have to physically turn the wheel back after the turn. Whereas MOST every other vehicle i've had you just gently let the wheel slide through you fingers and the car straightens itself after the turn. So lets say you were in a parking lot and turned the wheel to one side, probably like at least a full turn, then just took your hand off the wheel... the car would just keep doing circles until you straightened it back out.
Does anyone know what might be causing this? I built the whole car myself and nothing seemed out of the ordinary when i put it together.
I'd say the only thing that might pertain to this mystery is that there is probably 150k on the rack and pinion and pump.
first let me say:
there are no leaks
the fluid isn't low
